Question about GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur...
Ge profile arctic psc23sgpa stopped cooling/freezing. i dust cleaned the coils and checked for the cooling coils and all was good. slowly cooled back down to 0*/37*, worked fine for one night, now not
It's happened about a year ago. Same thing but it has worked since. It was purchased about ten years ago.
4 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
  • 235 Answers
SOURCE: GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Posted on Jul 05, 2009
  • 3382 Answers
SOURCE: GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Posted on Dec 03, 2009
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
GE DL213908 Side by Side Refrigerator not freezing or cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Refrigerators
Ge profile artica model PSC23SGPA Side by Side not keeping temp - lost everything in freezer and now frig is heating up. Can change temp to 0 but within a few seconds reads 24 (temp set does not hold)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
MY GE PROFILE REFRIGERATOR DOES NOT COOL IT SHOWS 7 ON THE DISPLAY AND THE REFRIGERATOR SECTION DOES NOT FREEZ ANYTHING IT SHOWS 4 AS TEMPERATURES.
ck the fans and clean the coil underneath / dirty coil will cause poor cooling and fan that is not going or is going too slow .. mm
Sep 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PFSF5 NJWA BB
There is a timer that determines the defrost of the cooling coil inside the back wall of the freezer. defrost timer may be located in the area of the controls for temperature. Look for a hole in that area and recessed in that hole you may find a clutch head screw. Turn this screw clockwise very SLOWLY until you hear one click. The freezer coil will be in the defrost mode for 18-22 minutes and then the refrigerator should return to the cooling mode. Make sure the condenser is clean and free of dust and dirt. Condenser is where the heat is removed from the refrigeration system and on most models it is located in back behind a removable panel. Reinstall the panel after cleaning the condenser.
Jun 01, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur... Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
