Question about Activision Cabela's Outdoor Adventures 2006 for GameCube
The Game Disc could not be read.
So, my GameCube will read the disc, until I press start, then it shows this... "The Game Disc could not be read. Please read the Nintendo GameCube Instruction Booklet for more information." I've cleaned it - it's free of scratches, my memory card has plenty of room and still won't play. It's the only disc I have that's doing this. What do I do?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
If you have not used the game disc successfully before and it is not scratched it could just be a bad cd and you should attempt to return it for a new one if possible. If it has worked previously you should see if anyone you know has a gamecube you could try it on and see if it works for them. One thing you could try to do is very carefully, take an ear cleaner and gently rub it over the small circular glass reader to clean away any minute residue. Some game discs are just more finicky than others. And as always with older game systems there is the tried and true technique of just turning the system off and on until it works.
Posted on Nov 21, 2013
My wii will not read pikmin 2. I have tried with 2 disks what should zI do
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
Apr 03, 2011 | Nintendo GameCube Console
It reads the disc and when i play it crashes, sometime it does not read it.
Single Disc
Feb 24, 2011 | Nintendo GameCube Console
I inserted my game and it said "the game disc
Single Disc
Feb 20, 2011 | Nintendo GameCube Console
I have a gamecube.on the game smashbrothers,it will play for a few moments and then it says:can't read disc,refer to gamecube manual but i don't have one.please tell me what to do.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 begin_of_the_skype_highlighting 1-800-255-3700 end_of_the_skype_highlighting for assistance.
Jan 19, 2011 | Nintendo GameCube Console
I was playing Super Mario Sunshine and then the game just said disk could not be read out of nowhere when I got to just one little part of the game it said Disk Could Not Be Read but it was only one part...
Single Disc
Jan 08, 2011 | Nintendo GameCube Console
An error has occurred but it is strange as it is not all the time some tines it does not happen 4 a day or two but when it does is can be in the first 5mins or four hours later it seams to random IE...
  • An Error has occurred:
    If you are getting the specific message, "An error has occurred. Turn the Power Off and check the Nintendo GameCube Instruction Booklet for further instructions." This means there may be an internal problem with the system.
    1. Check Individual Game Disc problems or Multiple Game Disc problems (depending upon how many games exhibit the problem) to see if the cause of the message is a dirty or damaged disc.
    2. If the disc appears fine or works properly in another system, this means there is an internal problem with the system. A repair will need to be set up. Please use our convenient repair options.
      Troubleshooting - Multiple Discs
      1. Some games may need to be cleaned. Clean each disc with a soft, slightly damp cotton cloth (use water only). Clean them from center towards the edges; do not use a circular motion. DO NOT use paper. Once they are cleaned, dry the disc using a dry portion of the cloth and wiping in the same style as you did to clean the discs. After all of the water is gone, let the discs sit for at least two minutes to completely dry before inserting any of them into the Nintendo GameCube.
      2. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
      3. Ensure the games are being loaded properly. With the power turned off on the system, replace a Game Disc (printed side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen. Try this with a few of your games.
      If Troubleshooting doesn't fix the problem, and it is happening with all your games, then your system will need repair. Check out our convenient repair options.
    3. Single Disc
      Single Disc
      6. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
  • Nov 25, 2010 | Nintendo GameCube Console
    Disc wont read
    The Disc could not be read:
    1. Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
    2. Determine if this happens with more than one game by inserting a different game into the system.
    If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
    If the error occurs with only one game, follow the individual game disc troubleshooting
    Single Disc
    Aug 06, 2010 | Nintendo GameCube Console
    Doesn't Read Disc
    I had the same problem. Just wipe the laser lens with a smooth cloth.
    Jul 09, 2009 | Nintendo GameCube Console
    Gamecube Recognizes what game the disc is, but cannot read it
    Make sure its in the right way (image facing up) then close the lid and press power button it should load the game up automatically (dont hold a after switching on the gamecube. if it persists take out the disc wipe it again blow on the gamecube to remove and dust then try switching on the gamecube without the disc it should show the menu, press up and there should be a question mark, insert disc, there it should show the game, press 'A' to confirm, then press start if it persists it is recommended you get it checked out because it could be the case that the disc is badly written like my lego starwars 3 on one of the levels it goes wierd and it spoils it really (i think there is a problem with all starwars games personally). Anyway Hope i helped as much as i could.
    Apr 30, 2009 | Sega Phantasy Star Online: Episode I and...
    Activision Cabela's Outdoor Adventures 2006 for GameCube Logo
    210 people viewed this question
    Top Activision Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    James Wishart
    ray gallant
    Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
