Question about PfaFF Creative 7570
7570, screen problems
There are some scattered pints appearing on the bottom of my sewing machine screen and it seems to be getting worse everyday. Any explanation for this?
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
.... yes, and you really don't want to know about it! Sounds like the screen is failing. If so, a replacement is the only solution.  This can be quite a few dollars.
Posted on Oct 23, 2007
Had machine stored in garage for 8 mons. after move and it turned yellow. is there any way to make it white again.
If it is plastic, generally, Nothing can be done to correct the discoloration. Unfortunately, when a machine is plastic, the plastic will tend to discolor especially if covered or near materials that dispense chemicals into the air. (Sometimes plastic bags/products or even other chemicals ie acetone, etc. can be culprits, others could be caused by heat, cold or sunlight.) There are many vintage sewing machines that have yellowed over time. Some only faintly, others have turned nearly brown. I have found no reasonable explanations for why some are worse than others. The good thing is, the color change will not affect the functionality of the machine.
To preserve your machine, store it in a household environment away from heat, cold, dirt/dust, or moisture.
Jan 27, 2016 | Sewing Machines
Machine sews fine until I use reverse and then the bottom stitching gathers up. Very annoying. I have adjusted bobbin tension and thread tension. What should I try next? Thank you.
Since you seem to have done everything possible to make it "happy", it is not likely that tension is the issue. With the problem becoming more aggravated, sounds like the feeding mechanism is not responding correctly in the reverse mode. Even refurbished machines come with a warrantty, so try that route before submitting it for an inspection by your local qualified technician.
Nov 07, 2014 | Sewing Machines
Need a pedal for my sewing machine homemaker everyday esm007
go to the website of and call them about
the pedal
Apr 15, 2013 | Sewing Machines
My Pfaff 1469 sews intermittantly. Footpedal connection seem plugged in properly.
if you've had the machine serviced several times and it come back
with the same problem then the machine wasn't fixed.
if you can explain more about the sews intermittantly,, I'll try to help
you with the problem.
Dec 07, 2012 | Sewing Machines
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
My machine is very noisy and squeals when sewing it gets worse when i sew quickly. it seems to need oiling. do you know how i can access the drive belt? thanks
check machine for oil hole locations and oil sparingly. NEVER oil a drive belt. The belt could be slipping which would cause a squeal.
Nov 05, 2009 | Janome Memory Craft 4800QC
Sewing Machine Home Maker Everyday ESM007
This is the manual for a Mezzo ESM007 sewing machine, it may or may not be the same as yours.
Homemaker ESM007 Instruction Manual
Aug 31, 2009 | Sewing Machines
Sewing machine Homemaker Everyday model HMFY-2300
Try this site manuals online , down load for free.
Jul 26, 2009 | Sewing Machines
Thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Mar 22, 2009 | Singer 3116 Simple
Sewing Machines Logo
69 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
