Question about DCS DD-224C Dishwasher
DCS DD-224C dishwasher stops running after 5 mins
The top drawer of the dishwasher stops after running for about 5 minutes. A technician thinks it is the controller board. I would like to try swapping the top and bottom boards but do not have instructions on how to remove the front panel.
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: need a service manual for wo-127ss DCS single wall
you can call dcs, they will be happy to send you a manual,
but mostly, this should be pretty simple, three small black phillips heads hold tthe console down, the are above the door when closed
from there the panel should tilt forward and off
becareful they dont leave much room. or very long wires
Posted on Oct 13, 2009
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Water won't go into the machine
The water lines to the dishwasher often have a valve to turn it off under the sink... make sure this is turned on. If this is a recent installation perhaps the flexible hose was bent as the dishwasher was pushed into place. It not then there is nothing left but an electrical problem. The water comes in through a solenoid (an electrically controlled valve) and through the timer/control board. Nothing will operate if the door isn't closed properly as a safety feature. Also there is often a float mechanism inside on the bottom that turns off the water if it floats telling the controller that there is enough water in the machine. Each of these possibilities has to be pursued.
Oct 18, 2013 | DCS DD-224C Dishwasher
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
No power
top drawer turns on runs aprox 3 min then starts to beep and we have to turn it offthe clock pops up and and stays at 2;00
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel 2 drawer dishwasher
When it sticks like this, does it continue to wash or does it stop?
Nov 27, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Jan 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
DCS DD-224C Dishwasher Logo
Top DCS Dishwashers Experts
Sal De
Chris Huff
Chris Huff
Are you a DCS Dishwasher Expert? Answer questions, earn points and help others
