Question about GE Ovens
Need GE wall oven JKP19G0K2WG service manual
Display on touch panel intermittently goes nuts displaying streams of garbage. oven may ormay not continue function in progress. need tech sheet & service manual to try to get to the bottom of and repair this intermittent behavior.
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Posted on Apr 06, 2009
fixyourboard
  • 310 Answers
SOURCE: F2 E6 on Whirlpool RBD305PDS14 double wall oven
Sometimes we see an intermittent electrical connection due to oxidation of the contacts on the keypad membrane tail. This can be easily cleaned so you can check this before investing in a new keypad. I posted some pictures and the procedure on our website. Here's the link:
http://fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
Posted on Sep 20, 2009
  • 5603 Answers
SOURCE: The control panel display light is completely dark
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Posted on Jan 31, 2010
  • 572 Answers
SOURCE: oven seems to work but the display panel dark.
Posted on Feb 11, 2010
  • 523 Answers
SOURCE: Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
Posted on May 27, 2010
F76 error code on ge oven
One of the most common problems with GE electric built in ovens is the error code "F7? shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4? nut driver and a Phillips screwdriver. - See more at: http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/#sthash.pVUT3Nzb.dpuf
Oct 14, 2013 | GE Ovens
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Jan 08, 2008 | Ovens
Monogram wall oven F9 error
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Dec 14, 2007 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
62 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
