Question about Water Heaters
Smoke from master radiator servowarm - Water Heaters
I have a servowarm Boiler Elite 80 and working fine until yesterday. Just seems to cut out and even after re-igniting it, cuts out after about 5-10 mins. I recognise this is an ancient boiler, but is there...
A boiler is a water heater? Sound to me like a thermostat problem and these are often obtained at W. W. Grainger at a price that is much less than if you call a service man in and he will just make some checks and change the thermostat.
The hard part is finding out which one you need.
Aug 31, 2012 | Water Heaters
I'm flushing my radiator in ford e-350 v8 with 5.4l......has strait water in it now......when i flush I'm trying to figure out where the heater return hose isto flush the core or do I even need to...
when i flush my radiator.i would first drain out all my old antifreeze.fill radiator up with water then put a bottle radiator flush. pour in radiator.then i will crank car up turn on heater wide open allowing radiator flush flush out radiaator and heater core when done i will drain out water. put in more water flush out all radiator flush out engine and radiator.then put back in antifreeze.you dont want to run water hose to heater core it will rupture it water pressure too high.
Dec 08, 2009 | Water Heaters
Hi I have a new house 2000ft2 with 12 radiator
CHECK IF YOUR RADIATORS ARE BALANCED IN THE WINTER IT IS ADVISED TO CLOSE ALL CURTAINS BEFORE DARKNESS FALLS IT SAVE A LOT OF LOST HEAT NOT A BIG JOB TO BALANCE RADIATORS BEST OF LUCK
Nov 10, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
Flow pipe to rad hot, return pipe not hot, no air in rad. new wall mounted Valiant combi fitted 12 months ago
remove radiator and flush through, knocking botton of radiator on to a heavy block of wood releases part blockage in radiator should this fal replace radiator remember to flush out rad/valves when you have radiator off best of luck
Oct 15, 2009 | Water Heaters
Servowarm Boiler Elite 30
try parts center web site or mjt controls both are helpful and have phone numbers to contact technical dept.
Nov 17, 2008 | Water Heaters
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Heating
you need to bleed your radiators - air has built up at top of radiators and water cannot flow- there will be a cover at end of radiator on one end or the other- very carefully turn venting cap until air comes out it will change to water and stop- repeat at all radiators- be sure you are turning right part of vent and be gentle - if it feels like you need Hercules strength -you are turning wrong part.At the end of this go down and verify boiler pressure of 15 psi
Nov 10, 2008 | Water Heaters
How to re pressurisecentral heating system
Hi tiger650,
I'm Harvey the Master Plumber.
Your problem is: The Alpha SY24 boiler has stopped working. The pressure gauge has dropped, you need to know how to re pressurise the system once the radiators have been bled
Every hydronic heating system is required to have a presure regulator. Most guys call it a feeder valve. Every one I've installed or worked on had one. It's job is to keep the water pressure constant by adding water when you release some air without over filling the system. Sounds like it's not working. Some types can be serviced, others cannont so you may have to replace it. If you're not sure what to do it might be prudent to check the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Water Heaters
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
