Question about Sanyo EM-S8000 Microwave Oven
Need dimensions for EMS8000W
Need installation dimensions
What are the dimensions of the following product Bosch Hbc84k51b
Check on the Bosh website. The Owners Manual should show the installation dimensions
Jul 23, 2014 | Microwave Ovens
Ewave microwave
Over the range microwaves are generally the same as far as the rear dimensions but you will still need to install new mounting brackets and drill new holes in the cabinet. Each brand is slightly differnt in its mounting.
Nov 25, 2013 | Microwave Ovens
I need the dimensions of the GE Spacemaker XL Model JVM1653WH01
For dimensions look at the GE Appliance web site at: http://www.geappliances.com/ then search for JVM1653WH01
This will take you to the product information page for the JVM1653WH 1.6 Cubic Foot Over the Range Microwave Oven with weights and dimensions, installation instructions etc.
Oct 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profileā„¢ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
I need the dimensions of the Whirlpool MH6130XE microwave to insure the opening is sufficient.
You can download the owner's manual and installation instructions here.
They'll give the dimensions.
Jul 23, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Cutout installation dimensions for sharp model kb6024ms
You can find a spec sheet which shows that info here.
You will need the free Acrobat Reader to view or print it.
I found that this document is easiest to read when you view it at 400%.
Sep 12, 2008 | Sharp Microwave Ovens
Microwave turntable does not turn
I have the exact microwave you do (ems8000w), the motor failed and I found this one worked perfectly as a replacement.
The original is impossible to find.
https://microwaveglasstrays.com
1 x 120v Microwave Turntable Motor 6RPM 4W # F63265G60AP (F63265G60AP) = $14.99
Good luck.
May 02, 2008 | Microwave Ovens
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sanyo EM-S8000 Microwave Oven Logo
47 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
