Question about Toshiba E-Studio 3040c Copier
How do you use bypass tray? - Toshiba E-Studio 3040c Copier
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
How do I get the pritner to pull paper from open tray if there is an envelope or special paper being used?
You need to set the correct paper in the bypass tray settings on the machine. Once that is input you will have to tell the printer that you would like to print on envelopes through the bypass tray. This is done through the printer preferences. Hope this helps!
Oct 07, 2014 | Kyocera Mita FS-4100DN Mono Laser Printer
HOW do I get my printer to stop trying to print from the bypass tray?
check the printer properties in Windows Control panel and see if printer settings are set to bypass tray
Sep 19, 2014 | Xerox Office Equipment & Supplies
Xerox workcentre c2128 When i put paper in bypass tray, sensor dosnot detect this paper
You must manually define the papersize and orientaion of bypass tray at the printer console or printer driver.
Then print bypass tray (e.g. Tray6 on our Xerox).
Apr 13, 2014 | Canon Computers & Internet
I have another Kyocere fs-1800. This printer will take the paper from the bypass tray first if I have paper in the bypass tray. If not it will take it from the drawer. I have purchased a fs-4000dn. It...
surf to Kyocera's website, download the latest software for your operating system, once you have the software installed you should be able to set all the options you would like in the printers control panel. such as start.. printers and faxes..... right click printer go to properties for all tray assignments and settings. (this instruction is for windows) bypass must be selected after you select print. hope that helps.
Aug 25, 2010 | Kyocera FS-4000DN Laser Printer
When trying to print, get error message to load paper into bypass tray. All printing preferences have the input tray as tray 1?
if all the other trays are empty
or the bypass is set as default
or the bypass has the correct tray size and no one else has it
then the bypass will be default...
Dec 09, 2009 | Sharp AR-BC260 Color Copier
Toshiba 281C Bypass tray
Problem isn't "solved", but have realized that the issue is related to the fact that the document I am trying to print is formatted for envelopes. When I print a regular word document (letter) it prints fine to the Bypass tray. It must have something to do with the fact that the document is 1000 envelopes. If I print to a PDF file, then print the document to the Bypass Tray I don't seem to have a problem.
Feb 17, 2009 | Toshiba Estudio 200L Copier
How to print 17 inch paper on Ricoh AP 3800 C
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
Feb 13, 2009 | Ricoh Aficio 1013F Copier
Printer always prints from bypass tray...
Check the setting in / on your computer. Make sure it is not set to default to the bypass tray.
Jan 08, 2009 | Xerox WorkCentre M128 Copier
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Toshiba E-Studio 3040c Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
