Question about Samsung SCX Office Equipment & Supplies
Usbprns2 exe - SCX Samsung Office Equipment & Supplies
2 Suggested Answers
SOURCE: need usbprns2.exe
please see and read this.. :)
http://www.tipsntrickstutor.co.cc/2010/01/reset-ml-1640-and-ml-2240-for-refill.html
Have a nice day!
Posted on Feb 14, 2011
I need a new Firmware Samsung CLX 3185fn
  • Download Link - http://sbx.sk/ADaN
  • Download and save Samsung reset tool for CLX-3185 to your harddisk
  • Extract compressed file.
  • Turn on your printer
  • Drag and drop file *.hd to usbprns2.exe or simplest double click ondownload.bat
  • Wait for re-flashing firmware complete
  • Restart your printer.
Do not turn off printer while reflashing firmware. It might damage your printer and might be it can't be recover anymore. Do the work with risk!
Aug 01, 2014 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Error message to replace Imaging drum on Dell 1235cn but it was replaced
You can reset the firmware by downloading the A01 (very first firmware release) and following the procedure outlined below;
I had the same problem:
Printer just clicked and panel indicated warming up. Tried all the USB stick thing and it wasn't reading it.
Search for usbprns2.exe in google, I ended up downloading it from some foreign site.
Place it on your desktop along with your firmware file xxxxx.hd
Connect the printer to your computer through the USB in the back panel.
Switch printer off wait a few secs then back on.
Press stop button - panel indicates download manager
Press stop again and "await image" appears.
On computer drag the xxxx.hd firmware file onto the usbprns2.exe.
The panel should indicate deleting addresses, then after loading addresses.
Printer reboots on its own and voila - working printer!
Mar 09, 2012 | Dell 2135cn All-In-One Laser Printer
I am using samsung Ml 1640 Mono Laser Printer .After finishing Toner Ink I refilled it and set the toner into the printer . Then both of the lights Green & Red light is glowing but the Red light is...
Samsung uses a chip that senses when the cartridge has ended its service life, the chip is located in the cartridge itself, refilling toner won't help, replace the cartridge with a new one. hope this helps ;-)
Feb 03, 2011 | Samsung ML-1640 Monochrome Laser Printer
Toner exsusted replace toner
To solve problem you need to download PATCHED by scx4300.exe 1.13 firmware (which you can Google and download it online)where additional reset procedure was implemented in.
To patch firmware you need to unpack archive in any folder then open commad line interface go to this folder then type "fix4300.exe SCX4300_V1.13_Fact_romdl.hd". If no error occurs you will find file "FIX_SCX4300_V1.13_Fact_romdl.hd". It's a patched firmware. The next step is to download this file to printer. Enter TECH mode, activate download by "Menu > Data Setup > Flash Upgrade > Local [OK]" then type in command line "usbprns2.exe FIX_SCX4300_V1.13_Fact_romdl.hd" to start download. During download printer displays: Data receiving > Flash erasing > Flash Programming > Checksumming > Download Ok then printer will restart. It's all.
To reset all counters and unblock printer enter Tech mode go Data Setup > Clear counters. In this menu you will find "Clear All CNT" instead of "Total Page CNT". Choose "Clear All CNT" then press [OK]. Printer will display "warming up" and LED will yellow for seconds then change to green. After reset all counters in report will be zero and toner 100%. You may repeat this procedure as soon as you need.
Feb 01, 2011 | Samsung SCX-4300 Monochrome Laser...
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Computers & Internet
Red light comes after refill
Download from this site http://sahat-tambunan.com/files/2009/Samsung-ML-1640-reset-raw.zip Raw Package for ML-1640 You will find 5 files in this package:
  • ML-1640_V1.01.00.83.exe is the official firmware upgrader
  • downl1640.bat is the firmware downloader (to printer)
  • fix1640.bat is the firmware patcher
  • fixml40.exe is the tools run by the patcher
  • usbprns2.exe is the tools run by the downloader
Unzip and start usbprns2.exe than downl1640.bat, at the end press any button and for 16 seconds you have printer reset.
And that is it, you are free to do what ever you want, but be careful if you reset with empty toner it will also show that toner is full.
Save the money for toner refill. See ya
P.S- Was this helpful? Say YES
May 22, 2009 | Samsung ML-1640 Monochrome Laser Printer
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
May 21, 2009 | HP Compaq Presario V3000T Notebook
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
29 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
