Question about GoJo GO-JO INDUSTRIES NXT Lotion Soap Dispenser, 1000ml, 5-1/8w x 3-3/4d x 10h
How to open a gojo fmx-12 soap dispenser - GoJo GO-JO INDUSTRIES NXT Lotion Soap Dispenser, 1000ml, 5-1/8w x 3-3/4d x 10h
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
I have a repeat of this question, posted earlier... "How do you open GOJO FMX-12 Soap dispenser"???? Help!
aimee149-
Instructions are available on GoJo's website at: Link
It appears you must push up from underneath, either with a key that comes with the unit, or without the key if an insert has been placed in the keyslot.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | SP Richards Go-Jo Provon FMX-12 Foam Soap...
Our 2 soap dispensers have stopped working. They have new batteries in them and full soap refills. Help
You might try taking out the batteries and wiping the area dry. It may be that the batteries are not getting a dry connection. Also, make sure the batteries are replaced correctly. There is usually a diagram with the battery placement on the lid where the batteries are installed. Also, sometimes the soap dispenser can get clogged. In that case, make sure to take the batteries out and then run hot water thru the area where the soap comes out. Hope this helps out.
Feb 23, 2011 | GoJo Purell 2720-12: TFX ? Touch Free...
How do I open the dispenser?
how do you open the provon soap dispenser so that you are able to refill the soap. We cannot open the dispenser. What is the trick?????
Jan 14, 2011 | SP Richards Go-Jo Provon FMX-12 Foam Soap...
When I refill the dispenser the Purell pours out and dose not stop. It isn't even foaming up.
when you put soap in do not cut tip or poke hole inbag just slide plastic tip in holder and close should work hope this helps
Sep 21, 2010 | GoJo Purell 2720-12: TFX ? Touch Free...
How do i open purrell dispenser?
it should have a snap at the top and it will hinge open so you can replace soap. you might have to work with but check it out it should pull towards you from the top allowing you to put bag back into it.
Apr 13, 2010 | GoJo Purell 2720-12: TFX ? Touch Free...
GoJo GO-JO INDUSTRIES NXT Lotion Soap Dispenser, 1000ml, 5-1/8w x 3-3/4d x 10h Logo
49 people viewed this question
Top GoJo Home Experts
jrand1970
Level 1 Expert
Mike
Tom Chichester
Are you a GoJo Home Expert? Answer questions, earn points and help others
