Question about Dryers
Need zing ear ze-301p 75w 125v
Need replacement sockets
  • 101 Answers
SOURCE: zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Posted on Apr 07, 2010
FixinFax
  • 3085 Answers
SOURCE: Need Zing Ear switch ZE 238S
http://www.ceilingfanparts.com/images/product.htm
Posted on Jun 27, 2010
karns
  • 122 Answers
SOURCE: light socket pt no. E306416 75W 125VAC
Most hardware stores carry replacement sockets. Go to Lowes, or Home depot and ask one of the workers there.
Posted on Aug 13, 2010
taran_2005
  • 10515 Answers
SOURCE: My fan would run only
First, check to see that the fan blades turn freely by hand and coast after being spun. If rotation is in any way stiff, this is a sign of dirty, dry, or gummed bearings, which can slow the motor. Sometimes the bearings can become tight and binding which can also be an issue.
Second, does the fan wobble at all? If for any reason the blade pitch is steeper on one or more blades than the motor is designed for, this will slow the motor. This can often be the cause of warping, or a blade being knocked off balance. This will also cause the fan to wobble or shake. See the section on balancing. You can bend the blades to a shallower pitch if they appear to be too steep, but be extremely careful as blade brackets can break easily.
Most ceiling fans made in recent years use permanent split capacitor motors, as they are efficient and reliable. However with age capacitors can drift in value. If the blades turn freely and are balanced, the cause of a fan running slowly is almost always a bad capacitor. The capacitor is a small black box or silver cannister with two or more wires attached, and is located inside the switch housing, motor housing, or inside a bell on top of the motor. It should be replaced with a capacitor of equal value, they are marked i.e. 6uf, 4uf, etc. Some fans have capacitors with two or more values, they should be replaced with the equivalent of those values by one or more capacitors.
Read :-
http://www.ceiling-fans-n-more.com/ceiling-fan-capacitors.php
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
SOURCE: Where can I find a replacement switch. Zing Ear
I have a Hunter Fan I bought in 2007 with the Zing Ear ZE-268S6 with the . Lowes sells a Zing Ear that works on my 3 speed fan. The chain is yellow so it will show above the light fixture. This is for a 4 wire. The color wires on the switch were black, green, gray and brown. You have the four markings L 1 2 3 so write down where each color wire attaches before you disconnect the old. All speeds work
Posted on Jul 20, 2013
I need a zing ear part ZE-301D+ZE-109M for a HUNTER CEILING FAN WITH LIGHT #28698
Fixya does not sell replacement zing ears. Check with a local appliance parts supplier.
Jul 05, 2016 | Hunter Dryers
I have a ceiling fan with a zing ear 301D 75w 125v socket and I don't know what bulb to use as I did not install the light and the warning label appears to be in a different language.
most all fans want you to use no more than 2 ea 60 watt bulbs
or 40 watt if there are 4 of them
now days most folks are switching to led lighting so it wont matter
May 09, 2015 | Dryers
Need a zing ear switch ze-268s6.
Let me know the model # of fan & I'll see if I have one. This Zing Ear # doesn't mean anything.
Sep 02, 2014 | Hunter Ceiling Fan Control Switch
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
Where can I find a replacement switch. Zing Ear ZE-268S6. Thank you.
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
Jun 27, 2011 | Hunter Ceiling Fan Light Switch Control
Need replacement switch for zing ear ze-256 switch. Used in a lamp, has off, lo and high positions
I have the same issue. I bought a ZING EAR dimmer but it won't fit in the space allowed by the pole the lamp is made from.
The switch is simple, the positions are: Off/On/Half.
The switch uses a diode to provide half voltage to the lamp. I have two solutions and I'm not sure which I'll use yet. First, I can use the dimmer but I'll have to get a 500K pot with a switch to fit in the hole. I'll attach wires to connect to the PCB of the dimmer. In essence, I'll remote mount the 500K pot.
The second solution is to get a rotary switch like this:
http://cgi.ebay.com/Lamp-parts-3-way-2-circuit-rotary-switch-5-8-TR-302-/380282854100?pt=LH_DefaultDomain_0&hash=item588a9fdad4
and use the diode salvaged from the original lamp switch. In my switch the diode is still good.
I know this sounds awfully complicated, but it's really not.
Randy.
Email me and I can give better details if you like.
westerville5595-now@yahoo.com
Mar 05, 2011 | Vacuums
Zing ear switch from a hampton bay ceiling
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
Dryers Logo
755 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
