Question about Epson dc-11 high res. Doc. Camera elpdc11 v12h377020
Elpdce1 reset the button to switch form the doc camera to a computer does not work. I can see the computer just not the doc camera
    Champion:
  • 219 Answers
Try a hard rebbot
Posted on Nov 27, 2013
Samsung Galaxy Camera EK-GC100 stuck on boot logo
Last option that you can do is to hard reset the camera, please take note that this procedure will delete everything on the phone. Please follow steps below:
Switch off the cell phone.
Then hold and press 3 keys: Volume Down + Power button.
Next release all keys, when Samsung logo appear.
Select option "wipe data/factory reset" using Volume Down button, and confirm with Power button.
Choose "Yes -- delete all user data" form the menu, and confirm with Power button.
After that select "reboot system now".
Jul 15, 2016 | Samsung Cell Phones
Tip
Reset the panasonic dmc-fx8 digital camera
hi, i'm not sure if it is a full reset, but it worked for me. i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and the _Turn Off the Camera and Turn On again_ message appeared on the sisplay. and remained in open position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was pressing the shotting button and holding it down while powering on the machine combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then. the time and other settings didn't changed. anyone knows other key combination?
on Jul 12, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Can't switch on
1) test the main switch for open, must be read continuity see the diagram.
2) replace with the same type alkaline, and full charges.
3) test if the polarities is in the wrong direction
4) clean contacts battery with c. cleaner very well.
God bless you
Oct 17, 2012 | Canon PowerShot SX30 IS Digital Camera
Over exposure
I had a problem with overexposed pics as well as horizontal lines. Try initializing you camera ( return to factory settings) by clicking menu and then scroll down until you see "Initialize". If that doesn't work, then do a power reset (This fixed my problem).
1. Remove battery from camera.
2. Hold power button for 60 seconds
3. Replace battery, and try taking pics.
If neither of these resets work, then you should try chatting with a Sony rep. You will your model number ( DSC-H70 ) https://www.docs.sony.com/startchat.asp
Sep 05, 2012 | Sony Cyber-Shot DSC-H70 Digital Camera
My dc7100 sff when turned on gives 9 audible beeps that repeat 4 X Then continuously 9 silent beeps over and over Any idea what the issue is?
Here is the solution:
Beeps 9 times:- System not fetching code Microcode
"update" else replace the system board
That deals with your bios.
I would try resetting the CMOS first.
More on fetching code:
http://en.wikipedia.org/wiki/Power-on_self-test
To clear CMOS:
<quote>
Clearing CMOS*
The computer's configuration (CMOS) may occasionally be corrupted. If it is, it is necessary to clear the CMOS
memory using switch SW50.
To clear and reset the configuration, perform the following procedure:
1. Prepare the computer for disassembly.
ã„CAUTION: The power cord must be disconnected from the power source before pushing the Clear CMOS
Button (NOTE: All LEDs on the board should be OFF). Failure to do so may damage the system board
2. Remove the access panel.
3. Press the CMOS button located on the system board and keep it depressed for 5 seconds.
4. Replace the access panel.
5. Turn the computer on and run F10 Computer Setup (Setup-utility) to reconfigure the system.
*When the CMOS button is pushed or the jumper is removed, both the power-on password and the setup password
<end quote>
Your error code page:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00219460/c00219460.pdf
PC homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=402163&lang=en&cc=us
Please rate me if this helps
Andy
May 11, 2011 | Compaq dc7100 Small Form Factor (PJ361UA)...
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
POOR COLOR QUALITY, NO MATTER HOW BRIGHT THE ROOM. SOMETIMES CAMCORDER WILL CATCH THE COLOR, THEN FADE BACK TO DIM LIGHT
I'm sorry that the video quality of the camcorder is poor. Sony camcorders will automatically adjust the shutter speed based on the lighting conditions. When video is being shot in low light situations, the camera will slow the shutter speed. This is normal operation and is not a service issue. To prevent this issue, record video in locations where more light is present.
You may use the White balance feature and check the operation. Refer the page 71 for more information. Refer the URL to download the Operating Guide:
http://www.docs.sony.com/release/DCRDVD105-205-305.pdf
You may also perform a power reset and check.
Performing a manual power reset
  1. Turn off the camcorder.
  2. Disconnect AC power adapter.
  3. Remove the battery pack.
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
Jan 04, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Lens cycles in & out upon start up and view finder blurry.
Here's the procedure for a manual reset...remove the card and battery...press all the buttons...insert the card and then the battery...turn on the camera.
Sep 10, 2009 | Olympus FE-340 Digital Camera
Nav-cam 7000
thairs a reset switch on botom left edg .That you need the stilus to move it.thay ship it in the off positon to save battry life. Thairs actulay two switches a push button soft reset and the hard soft ware slide switch the slide switch is probbly in the off posithen.
bikerroger@gmail.com
Jan 17, 2008 | Navigator DPC-640A Digital Camera
Press the reset switch
Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
Dec 26, 2007 | Panasonic NV-GS11B Mini DV Digital...
Epson dc-11 high res. Doc. Camera elpdc11 v12h377020 Logo
29 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
