Question about Kitchen Appliances - Others
Candy cld135 How to remove door's seal?
    Champion:
  • 252 Answers
Very carefully, little padawan
Posted on Nov 26, 2013
How do i change a candy washing machine front door seal?
you can use some very strong string
much like putting in a windscreen to an old car
its called paracord try ebay for a couple of meters
Oct 01, 2014 | Candy Washing Machines
How to find candy double oven model number
should be by the main oven door seal
May 19, 2014 | Candy Ovens
Problems candy cm1146
This is not a cotton candy machine.
Nov 17, 2013 | Kitchen Appliances - Others
The rubber seal has been damaged (ripped) can I replace the door seal?
yes you can,if you google "candy fridge spares"you will find lots of suppliers.
Oct 16, 2010 | Candy CPL321K Refrigerator
Replacing Door Seal on AQW130 Candy Washer Dryer
JUST THE SEAL IS ALL THAT IS REQUIRED AND A GOOD SET OF TOOLS AND MECHANICAL SKILLS, i AM IN THE USA SO CAN'T RECOMMEND ANY PLACE TO BUY IN UK
Jul 28, 2010 | Candy AQW130 Front Load Washer / Dryer
Candy washing machine
door seal replacement can be done with a little skill and a bit of common sense, 1st thing to do is buy a replacement quoting make model etc, then you will see how the seal is shaped to fit, unplug the machine and work from the front, open the door and remove the thin wire clamp from round the edge of the door seal, remove from the lip of the cabinet and that will enable you to see inside the casing, there is a wire spring or an adjuster on the drum end of the door seal, remove that and the seal will pull off with a gentle pull, refit as removed, take note how you removed wire etc, check for leaks and state of fit before leaving machine unattended and running difficult job hard to describe in writing, but not too hard with a little thought
Sep 17, 2007 | Washing Machines
How do I replace the door seal
like much refrigeration, the door seal is near impossible to replace - it is foamed in. you are faced with a new door at vast cost.
Apr 29, 2007 | Candy CPC220 Bottom Freezer Refrigerator
How do i fit a new door seal???
disconnect from mains not that easy first time. undo clip holding seal to cabinet. peel off seal and push inside drum remove top.i remember seal is held to tub by a giant jubilee clip but varies with model. undo clip and remove seal complete. fitting is more difficult lubricate slot that fits flange of tub with washing-up fluid - essential start at top fit an inch or so of slot onto tub flange. work in both directions forcing slot onto flange with thumbs as you go round. refit giant jubilee clip. refit seal to cabinet and refit cabinet clamp. test for leaks on rinse as water level is higher. this job is a knack so persevere
Mar 28, 2007 | Candy CN126 Front Load Washer
Kitchen Appliances - Others Logo
35 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
