Question about D-Link Computers & Internet
Router dsl3780 red internet light keeps coming on
The red internet red light on the router keeps turning red.
    Novelist:
  • D-Link Expert
  • 199 Answers
Usually indicates problem with the router's internet connection. Check the LAN cable between your internet modem and router and try a new cable. Reboot both devices. Direct connect to the internet modem to see if it is working correctly with interruption.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Posted on Jan 06, 2017
2 Suggested Answers
  • 415 Answers
SOURCE: was working ok then internet down and red light on
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Posted on Aug 08, 2011
The router keeps losing Internet connection
Keep a eye on Internet light. If it turns RED, then its a problem with internet connection..
As a qucik fix, Try to reboot the router when you face the problem...
Apr 11, 2011 | NetGear DG834 Router
The second red light doesn´t turn off... Please relpe me The router never turn off anyone light... if its is desconected.
If you will disconnected with the internet and router will still open then router will not turn off it will keep on blowing.
Oct 07, 2010 | D-Link Computers & Internet
Internet turns red after 10min of restarting and resetting router
Please make sure that the router is properly configured then only the internet light will be green
Talk to your ISP regarding the router configuration
May 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
The red led light on the internet connection on my d-link router is on. i cannot connect to the internet now. i have a green light above the dsl connection and their is one other green light on. i have...
1st: Have you paid your bill?
2nd: Have you power cycled?
Full Power Cycle is as follows:
Turn off all components plugged into the router(Computers, Printers, etc.) Unplug the power from the router. Unplug the data cable(DSL, Coax) going TO the router. Wait aprox. 1 minute. Plug data cable and power cable back into router. Wait about 1 minute. Turn computers back on. Problem Solved?
If not and you're using DSL make sure all DSL filters are in place and that none have come undone. Make sure the phone line is still plugged in. Problem Solved?
If not contact your ISP and ask if they are doing any maintenance in your area that may by effecting your service. Ask them to perform a line test on you. If all else fails ask them to have a technician come out and help solve the issue.
Oct 23, 2009 | D-Link DI-704P Router
Computor doesnt connect to internet states a local network cable is unplugged 4 green lights on routerand one red light turn off all power and unplugged cable also reset button but no internet connection...
If the red light is your DSL light it means you have a line fault or no internet connection. Contact your provider
If the red light is your broadband / internet light - it means you are not logged on properly. Chck your username and password are correct - especially after the reset!
Oct 06, 2009 | Belkin (F5D5231-4) Router
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Modem keep rebooting.
It sounds like you have a bad modem. Have you tried to plug the device into a different power outlet? This will rule out that it's a possible power issue in the outlet.
If no change by trying a different outlet I would replace modem.
Hope this helps.
MO
Jul 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Belkin Router keeps frezing.
Try changing the channel of the router to 1,9 or 11, and make sure that there is no cordless phone near the router or the wireless computer, this will help mionimize wireless interference. If this may not work you may want to adjust some settings on the advance wireless settings of the router like the beacon(set it to 50) and RTS/fragmentation(2304).
May 07, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
50 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
