Question about Global Granada Series Lowback Multitilter Chair
3212 Low Back Multi-Tilter armrest came off
Arm rest came off and I can't seem to reattach it
How to fit an upgrade armrest on an x type jag?
The center arm rest is attached to the console by 2 small Hex cap screws. The arm rest and intermediate slide panel are attached to the same hinge assembly with rivets.
to replace the upper arm rest, 1st remove the assembly from the console by removing the 2 hex screws this will allow you to work outside of the vehicle on a work bench. 3 rivets hold the arm rest to the hinge. You will need to drill out the rivets using a 1/8" drill bit. and install the replacement arm rest using new 1/8" pop rivets.
see illustration
Feb 07, 2015 | Jaguar X-Type Cars & Trucks
Remove center armrest hhr
Hi Konakalela, I'm Al the owner of Big As Auto Repair
Most arm rest have a round trim cover on the side of the seat that's removable. Simple remove that cover and there is a bolt behind it that holds the arm rest remove it counter-clock-wise and pull the arm rest straight outward. For further assistance go to my website. Have an awesome day Konakalela.
Auto Repair
Dec 21, 2014 | Seat Cars & Trucks
How do I remove middle armrest on 2008 Honda accord sedan
Most likely 3 screws hold the armrest lid on.Towards the back.
Nov 12, 2014 | Cars & Trucks
How do i take off the armrests from the bucket seats
  • On most vehicles the arm rest are attached the same way, here is something you can try...Put the armrest in the upright position. Look along the bottom and sides of the armrest where it connects to the body of the seat. There should be small circles like tabs if the armrest is made of plastic, and there should be a seam that you can look through if the arms are made of cloth.
  • Pop out the tab or peel back the fabric to reveal the holding mechanism. If the chair is screwed in then you'll need a screwdriver, and if there's a nut or a bolt then you're going to need a socket wrench.
  • Hold the armrest up and make sure it doesn't move. Unscrew or unbolt the arm from the bucket seat. Pull the arm outwards once the hardware is removed.
  • Nov 13, 2012 | 2007 Dodge Grand Caravan SXT Minivan
    Removing arm rest on driver seat
    using a flat blade tool like a small flat blade screwdriver, release retaining clip on arm rest and pull armrest from seat. slip the screwdriver between seat back and armrest and pry up on the retaining clip.
    Dec 31, 2010 | 2001 GMC Yukon XL
    The arm rest does not move to a parallel position
    Un zip the cover on the armrest and pull it up to expose the bolt hole. unbolt and remove the arm rest and see what parts are damaged, sometimes it can just be tightened.
    Feb 12, 2010 | 1990 Ford Bronco
    How do you remove the armrest on the front seats?
    The armrests have covers that can be removed. Locate the zipper on the arm rest. Once you unzip it pull it toward the back of the arm rest and this will expose the one bolt that hold the armrest on. You will need a large torx and rachet to get it off. Once you take out that bolt the armrest will come right off.
    Feb 02, 2010 | 1995 Ford Bronco
    Arm Rest on drivers side ''99'' Cherokee
    You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. then you can pop the armrest out the back fo the panel
    Jul 28, 2009 | 1999 Jeep Grand Cherokee
    The driver side window has seem to come off the track.i see clips holding the sides together, but i can't get the armrest to separate from the door.
    There are a few screws that you have probaby missed inside the arm rest, underneath and on the end of the arm are lights he screws can only be accessed after you remome these light assemblies in the arm rest carfully pry the lamp assembly loose using a small screw driver or similiary tool and then you can reach the screws and remove the arm rest
    Apr 30, 2009 | 1991 Cadillac DeVille
    How do i remove the armrest on my winstar
    The real real answer. If the threaded stud is in the armrest there is a clip at the bottom of it you have to push it up and pull the stud out with vice grips twisting as you pull out. If both the studs are in the chair you have to make sure the clip is pushed up & out of the way then simply line up the arm rest and push it on. It should clip into place. Hope that is clear enough. Also I would put some Lock Tight on the threads. (Blue)
    Apr 30, 2009 | Ford Windstar Cars & Trucks
    Global Granada Series Lowback Multitilter Chair Logo
    Top Global Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a Global Office Equipment and Supply Expert? Answer questions, earn points and help others
