Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Aquos 37" has green & white horizontal lines across whole screen
  • 115 Answers
If it is not dropped by any mis handling,required service
Posted on Nov 21, 2013
3 Suggested Answers
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
cheater21
SOURCE: Sharp Aquos 37" picture
Those lines are because of "Interlacing". a REALLY bad case of it. what are you watching when this happens?
Posted on Jan 02, 2009
Screen issue with Panasonic plasma tv. Model TC-P42S2.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Aug 25, 2016 | Panasonic Televison & Video
Horizontal lines showing behind tv menu
Normally the menu is generated in the LCD Control Unit. If your menu looks good, but the defect is behind the menu, I would suspect the Main PCB. Good luck to you. Part# is DUNTKD934FM01-V1.
Jun 17, 2016 | Sharp Aquos LC46D62U 46-Inch 1080p LCD...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Blue Grey Horizontal lines across Sharp LC37D40U top 3/4 of screen
could be the Tcon (logic Board) thats usually the cause of lines
Feb 20, 2012 | Sharp Aquos LC-37D4U 37 in. LCD Television
Feb 28, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Thin line across the screen
I'm guessing that this is a CRT based TV, not an LCD. That being said, the problem is a failure of the vertical circuit. Usually this is a small flat IC (LA7837 or similar). Try resoldering the pins if you can first. If that fails to resolve the problem, replace the IC. Please be aware that there are potentially dangerous high voltages present even when unplugged.
Keep us posted.
Dan
Jan 21, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Jan 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
77 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
