Question about Sony Ericsson Cell Phones
Parrot v511c - Sony Ericsson Cell Phones
Mki 9100 parrot to fit in my 03 plate merc clk. do i need an extra cable?
They advise using a professional installer. And I found this
http://dbinstall.parrot.com/compatibility_pdf.php?model=1031&ck=12
For the CLK there is a special kit
http://www.ebay.com/itm/MKI9100-CT10MC02-Mercedes-CLK-Class-Parrot-Bluetooth-Handsfree-Car-Kit-/141233049285
and mentions a lead
Kit Consists of the following:
  • MKI9100 Parrot Bluetooth Handsfree
  • CT10MC02 Parrot Wiring Harness Adaptor Lead
Parrot MKi9100 https://parrotcontact.parrot.com/.../MKi9100_User-guide_UK.pdf ยท PDF file Parrot MKi9100 - 4User guide Installation WARNING: We advise our customers to have the Parrot MKi9100 fitted by a professional. Before you begin
Dec 30, 2015 | Cars & Trucks
How do I rest parrot password
Try using the pin code 1234, as that is the automatic pin code for many new parrot devices.
Here are some quick start guides from the company
http://www.parrot.com/usa/support/parrotck3100ck3300ck3500/
Jan 26, 2015 | Parrot Cell Phones
Parrot keeps "calling" and counting time when I turn on car....bluetooth is connected to phone but I did not dial anyone!
You will need to update the software in this parrot, you can do this by downloading the parrot update manager from parrot web site, you will need a Laptop with Bluetooth to send the file to the parrot. If you cant do it the have a look at parrot.com and look for your nearest parrot engineer.
Jun 15, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Carnt pair phone with ck3100
go to settings then paried devices and delete all the previous paired devices, the parrot will only hold 5. if this dos'nt work you may need to perform a software update, this requires downloading new software from parrot.com/support and sending via bluetooth to your parrot. check parrot site for compatability with your phone.
Mar 04, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I can't pair my parrot ck3000 with my 5800. I erased the memory of the parrot by still it says it can't be paired.
you will need a software update, this can only be done using a computer and the correct parrot update cable, i would contact your nearest parrot accredited installer by looking at parrot web site.
Mar 04, 2010 | Parrot Par Ck3000 Evolution Ck3000...
Problem updating Parrot LS-GPS
The Parrot manual states that the software update can be conducted via bluetooth (BT). I've managed to get BT connectivity both the laptop recognising the Parrot as a headset, and indeed it cts a PC speaker in the mode, and also from the Parrot linking to the laptop. But wehn using the Parrot Software update tool, and attempting to connect via BT, non of the displayed COM channels work. Authentication fails. The laptopn connection also only stays up for about a minute. Confusingly the Parrot also offers an update item in one of its menues, and supplies a 4 digit passowrd, but I can't see how this can be used. Any ideas?
Sep 14, 2009 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
Cell Phones Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
