There is P11 error code on IPSO washer. it does not start.
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: I have an error code on Whirlpool washer.
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
I have an Ipso washer and had to cancel a load because the water was frozen. Now the green lights that say “door” and “wash” are blinking, and I can’t get it to start.
there's no way help as a correspondent in a forum, you will need to contact a washing machine repair person and get him to take a look at it eric
Jan 02, 2018 | Washing Machines
P11 IS THE CURRENT ERROR CODE APPEARING IN MY IFB WASHING MACHINE. PLS ADVISE
You are not very clear as to what else is going on with your washer.
Is it getting any power, are the dials on all cycles functional? Sorry I know what an IFB Washer is but there can be quite a few malfunctions. Please elaborate if possible.
Dec 24, 2016 | IFB Washing Machines
Ipso washer keep filling up with water
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Sep 23, 2014 | IPSO Parts IPSO 111/01705/00 Washer PANEL,...
Drum is stuck
hi have u lost any small items i have done a few washers were socks get throungh gap in drum at front when they role up between inner and outer drum they will lock it up
Feb 14, 2014 | IPSO Parts IPSO 223/00102/40 Washer...
I have ac tcl model tac-42cf is not working and have error code in the display,how i can fix this trouble for this error?
I have the same problem..but i fixed that. if u have the same type with mine; TCL split type ac, TAC-42CF/A,380V 3N~. Then u can try this.
1. open indoor panel.
2. find 2 cable in socket pcb that is p11 And P12, u plug p12 on p11,and p11 on p12.
3. if not solved, try the same just like point 2 on power suply 3phase cable R.S.T try S to R, or else.
4. hopefully ur problem solved.
Aug 14, 2012 | Cars & Trucks
Error code Ld. Checked-no kinks or plugs. Did
Hi there.I'm just thinking that LD could be a faulty lid switch,have you checked that out?
Jun 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I need a wiring diagram for a ipso we-181 washing machine
most washing machines have wiring diagrams tucked or taped in the control area of the washer look for a folded paper this may help
Oct 22, 2009 | Washing Machines
Messed up Bootmgr on a Nokia IP350
Have you tried the steops below
1. Get the IPSO image you want to install.
2. Copy it to an internal host capable of FTP.
3. Connect to the console on the IP130 and start it up, when you
get past the bootmanager part where it shows the prompt
BOOTMGR[1]>install then ftp or help a few other commands
4. The interactive prompts should help you figure out what to do (like assign it an IP and ftp to the server).
5. Let it install the image and reboot.
Jun 15, 2009 | Nokia IP 350 Firewall
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
