Question about Toshiba satellite c660
Sound problem my lap export cracking sound and i changed audio driver but it didn't make any sense ..!
  • Hamza Zaki
    Hamza Zaki Nov 21, 2013
    i changed the driver more than time ... but it isn't work i guess that there is something should fix inside such as changing a piece or something ??
  • Hamza Zaki
    Hamza Zaki Nov 30, 2013
    but even i put the headset it still crackling
  • 20 Answers
Insert a headset into the jack if the sound comes thru it,if sound comes into the jack then check speakers and get the speakers changed.
if both the sound jack and the speakers does not work,check the sound ic on the mother board....
Posted on Nov 21, 2013
Toshiba Satellite C655 crackling audio
hello . fixya appreciate to get some helpe here ... i got a lap of toshiba the model is satellite c655 . and recently i surprised that the speakers export crakcling sound .. . but as i remind that wasn't occur until i restore my lap of the origin windows 7 virsion ...in while i try to fix the problem i changed the sound driver lots but did'nt make make any sense ... how could i fix that problem and thanks for effort .
Nov 11, 2012 | Toshiba Satellite C655-S5212 Laptop /...
Iam not having the audio device in my lap top unable to raise the volume or remove the mute itry to remove the mute in control panel clicking the option of sounds but didn't work out they said...
it seems that your windows did not installed properly. some files may be missing. so you should repair your window from the windows cd and then check out your volume control option. If still it would not work then check out the audio drivers.
May 30, 2011 | Computers & Internet
Ican't hear any sound from my lap after formatting it. so plz give me solution for it.to install audiodevice for my lap
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Creative Labs Sound Blaster Audigy LS...
My sound crackles i changed the speakers on my dell inspiron 6400 and it still crakles during audio I believe the sound is built into the mother board any suggestions other than get a new laptop
Well, try a set of headphones and listen. If it is still cracking, then you do indeed need another motherboard, because your audio pre-amp has blown a diode causing your waveforms to break apart mid-wave. That may not make perfectly clear sense to you, but, try imagining a wave on an ocean. it goes up, then goes down. In your pc's case its going up then dropping sharp and abruptly like a cliff. Since the driver is working, we know it is not the audio chip itself. It is my opinion that the audio preamp is malfunctioning.
Oct 26, 2009 | Dell Inspiron 6400 Notebook
I formatted the my lap........ VGN-N365E cant get
Just a reminder. You should install also your SOUND CARD driver, just like your VIDEO CARD driver.
Apr 09, 2009 | Creative Labs Sound Blaster Live! 5.1...
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
Lap top sound
You need the Microsoft UAA drivers for your operating system download them uninstall any sound drivers through device manager right click driver and uninstall then install M/soft UAA drivers reboot when restarted go to device manager, right click sound driver and choose update driver will go on net and find and install them
Oct 17, 2008 | Computers & Internet
No sound
Sir, I have one compaq c 700 lap top. Its sound system is not working after I formatted it. kindly guide me as to how I can be able to instal sound in the lap top.
Sep 09, 2008 | Compaq Presario 700 470024-192 Notebook
Sound driver problem
I have acer lap top of model no. 290E when we play the the song in window player and DVD it wil just ask install sound driver.
Jul 26, 2008 | Edirol UA-4FX External Sound System
Toshiba satellite c660 Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
