Question about Xerox WorkCentre 7120/P Printer
Xerox workcenter 7120 initialization code - Xerox WorkCentre 7120/P Printer
  • Gerardo Riz Nov 24, 2013
    The initialization code you can got it from E-doc on service manual that's available at xerox delers.
  • gregworobets
    gregworobets Nov 30, 2013
    What is it you are trying to accomplish/resolve?
  • 2072 Answers
SOURCE: xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Posted on Mar 28, 2008
  • 2072 Answers
SOURCE: I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Posted on Jan 25, 2009
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
Fault Code: 016-405 Xerox WorkCenter 5335
This FC (fault code) 016-405 means that there is an error with your security certificates on the 5335 .Copy the link below into your browser and type 016-405 in the search field and it will provide guidance on how to resolve this issue.
NOTE When working with security certificates on Xerox equipment it is recommended you call them for support or have your IT person investigate, this is because if you delete any certificates and not initialize them again you can break some custom services installed on your machine.If you;re not sure if you have custom services running please call your IT department or Xerox for assistance.
http://www.support.xerox.com/support/workcentre-5300-series/support/enus.html
I hope this helps ...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Xerox 7120 error code 093-320 reset
bonjour j'ai un code erreur sur ma xerox workcenter 7125 je trouve pas de solution si qlq px m'aide merci d'avance code 093-320
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
Inside yellow
please i need how activation code xeror 7120 workcente
Jan 14, 2014 | Xerox WORKCENTER 6505DN COLOR LASER MFP,...
Xerox 7120 activation code
i need activation code xerox workcentre 7120
Nov 25, 2013 | Xerox Office Equipment & Supplies
I have workcenter c450 machine the coad comes in this machine the coad number -04-361
Nvram recovery card to initialize the nic if you don't know how to do this you're better of hiring a tec, it will be cheaper and you won't break the printer. 11_6_2013_4_52_15_am.png
Oct 08, 2013 | Office Equipment & Supplies
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox WorkCentre 7120/P Printer Logo
129 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
