Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquairius wml 720 washes fine and dries but drier goes for hours, what is the problem
2 Suggested Answers
  • 414 Answers
SOURCE: my hotpoint wml 720 taking hours to wash whats
If the cycle time is extended this could be due to the unit not heating (element or stat) or not pumping out sufficiently to let the pressure switch drop out ready to refill for the rinses or there is a significant drop in water pressure or tap not fully on and the machine is taking too long to fill up after each drain of the w/m.
Hope this gives you a starting point, good luck.
Posted on Jul 11, 2010
My 65 corvair 110 won't start up , when it was running fine hours ago before I washe engine
Dry out all the ignition parts, distributor cap (inside and out) plug wires and caps including coil wire with a hair drier or heat gun on low. If no hair drier is not available dry the best you can and give a light spray with WD40.
May 02, 2015 | Cars & Trucks
My drier dos'nt dry my washing
Is it pumping out the water?
try laying the draining hose on the ground or a bit lower than the machine if possible.
Jan 15, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
Why does my hotpoint aquarius WML 720 will fill up but will not wash where would the filter be
you may have a bad door switch should check with a multi meter. can also check ur water pressure switch and motor coupler or belt if applicable
Jul 13, 2014 | Hotpoint Washing Machines
My hotpoint wml 720 taking hours to wash whats wrong
Jul 11, 2010 | Hotpoint Washing Machines
Drier not working
take top off. you will see drier manifold going across top of machine with stats mounted on it. one or more of these stats is resetteble ie has a little button in the middle. press to reset. some hotpoint have a thermal fuse mounted on the manifold so if present, check this for continuity as well. with top still off, put on dry and check fan working as well.
if you get it going and fault reoccurs, then there is a blockage in the drier duct
Jun 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
