Question about Acer Aspire 3004WLCi Notebook
Computer not powering on
I own an aser aspire 3000 laptop, the green light is not staying on for me to use it. i removed the battery, also changed suckets still no results. had the computer less than one year never had a problem, please help.
  • 105 Answers
Re: computer not powering on
Please check the Power adaptor, whether it is giving output or not. If it is ok then check the batterry connector and clean with a soft cloth soaked with alchohol then try it.
Posted on Oct 13, 2007
  • 457 Answers
Are you sure the adapter to charge the battery not had it?
Posted on Oct 10, 2007
0 characters
3 Points
My leptop is not turn on aser aspire one
Please do the following.
Check your power cord for any sign of damages. Check if the light is still lit in your power cord.
Remove the battery and use the power cord only. If you get power, then your battery is defective.
Let me ask you one question. When you say it doesn't turn on, does it mean that there's no sign of power or you are getting power like lights or something like that but the computer just don't boot up to the normal mode?
Mar 09, 2013 | PC Laptops
Acer Aspire 7000. Power light comes on and stays on. HDD light flicks twice then goes out. No noise or screen change. All dead. Think I may have hibernated it last shut down. Removed power supply and...
If the laptop is in hibernated mode, if and when it comes on, go into power options select hibernate and uncheck box to the left to disable this feature and click apply.
Jun 03, 2012 | Acer PC Laptops
Power supply flashes green and no lights on laptop
Remove battery pack, press and hold power button for 5 seconds, then put battery pack back in and restart pc. This should take care of it. A bad memory stick can cause problems like this as well.
Nov 12, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
Oct 16, 2009 | Acer Aspire One PC Notebook
Why does the green light stay on, like the computer is thinking but the screen doesn't stay on?
The green light might mean your laptop battery is being charged up. Having the screen go out means you or someone has set the monitor to power down after X minutes of in-activity.
You can look in both the screen saver and the power management sections of your operating system to find out what is going on for the monitor.
Oct 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Motherboard bettery change
take this user guide and reset bios by removing battery of laptop (button cell) :
Note that It's very simple once you got the exact location of battery.
May 15, 2009 | Acer Aspire 3000 Notebook
Will not turn on
Can you turn it on while it is plugged in, but with the battery removed? Try holding the power button for 10+ seconds.
If not, I would bring it to a tech for warranty repair.
Mar 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3004WLCi Notebook Logo
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
