Question about Sony KV-24FV12 24" TV
Blue picture with normal sound
When I switched on the television, it only shows blue screen. Sound is playing normal. Remote with every other things is working fine.
Big display
Posted on Nov 21, 2013
    Scholar:
  • 155 Answers
Is the video plugged in? It may have fallen out - this is if you are using RCA style jacks - one for video, and two for sound
techman
  • 3130 Answers
SOURCE: No signal
That sounds about right my friend. Those sets do have two tuners and Ive seen the problem your desribing. Unless of course that the microprocessor and tuning circuits are goos also. I would call a servicer if I were you unless yopu know your way around the inside of the tv set as it does have alot of High voltage even when its unplugged Good Luck
Posted on Jun 07, 2006
techman
  • 3130 Answers
SOURCE: Sound but no picture
You have a vertical sweep problem. Since this Sony tv has no user replaceable parts inside of it, your best bet is to call out a pro to assist you in this repair.
Posted on Sep 23, 2006
CompuGuy44
  • 432 Answers
SOURCE: No Picture, Sound Fine
Hey John, How many times does the light blink? No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some newer models of Sony TV sets, this code means that T8005 is defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. I suggest you do a hard reset. Unplug the power cord for 4 hours. Then plug it back in and check it. If it works, great. It not, cost of repair for this is usually around $150 - $250 plus the house call.
Posted on Jun 26, 2007
SOURCE: Television is "locked"
I dont have the answer, but do have the same problem and just wondered whether you had solved the problem....our son is 13 months old and I think he is the one who caused the tv to be locked too !!
Posted on Aug 26, 2007
SOURCE: no signal
Good day. Try to check the tuner section. You mention that it functions good in auxilliary functions. check tuner section and system IC.
chris
Posted on Mar 30, 2008
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Fix blue screen av27870
Hi. Switch off (mains switch) the VCR. Then see if you can change channels with your TV remote. Blue screen mostly means that no channel has been programmed. If there is , you should at least have the sound. So, if you have sound, there is an internal problem in the TV. If no sound appears, try to get into setup mode (button Menu)
and programm your channels. I suppose there is signal on your normal areal connection. Check this out with another TV set, or use the tuner from you VRC. I know there are a lot of possibilities, but you can sort this out, step by step. Good luck.
Oct 18, 2014 | JVC Televison & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Only use to play games,,, now we have sound but no picture blue screen any suggestions?
Try a different input and see if you get a picture back...try tuner input. A blue screen shows up if it doesn't see an input signal. Try the game on another set. Problem may be with the game.
Mar 10, 2010 | Toshiba CF35F50 TV
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
I have a lexsor plasma tv, blue power on tv but no picture screen as if switched off. Remote working on as remote light signal is showing
I have lexsor LCD 32" sound is on no picture,have had to wait for 1 hour for picture to come on ,now nothing?...
Jan 21, 2010 | Televison & Video
Problem with 42" vizio on/off switch
Blck with sound would be bad inverter or backlight
Blue withoutsound again inverter on the decoder is bad this does power both backlight and decoder so I would say inverter but check it into a shop as I cannot see the TV from here @ @ But I am sure my advice will give you a level playing field with the repair shop.
Thanks and please do rate postivly have a happy new year!
Dec 31, 2009 | Vizio GV42L 42 in. LCD Television
Blue screen
It sounds like your kid switched to a different input. I am not sure what you have hooked up where but on your remote at the top there are two buttons - one is labeled HD.S and other is SD.S - I do not have my remote handy but am going from memory. The HD.S button switches to the hi-def inputs and the sd.s switches to the standard definition inputs. Try pressing these and switch around until you see a signal again. You will need to let the input "stabilize" and the picture appear so when you switch inputs give it 10 seconds or so before moving on.
Aug 06, 2008 | Optoma RD50 50" Rear Projection HDTV-Ready...
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Jan 21, 2008 | Kenwood KVT-617DVD Car DVD Player
Sony KV-24FV12 24" TV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
