Question about Nvidia Computers & Internet
Screen flickering on windows 7 boot
I have a nvidia 660 gtx and a dual monitor display with 2 samsung 2232 bw. I use a dvi-dvi to connect the main monitor and a hdmi-dvi to connect the second. When windows 7 is booting, the main monitor flickers in a very fast way (about 10-12 times per second) and then the screen goes black. Being unable to have access to the main screen of windows7 , I execute a cold restart pressing the restart button. After the system restarts, the screen flickers for about 10 seconds and after that everything is ok. Before this cable setup, I was using 2 dvi-dvi cables and I had the second monitor going black EVERY TIME I opened a window in it or dragging a window in it! I solved this problem by changing tho dvi-dvi cable with a hdmi-dvi, but the problem with the main monitor remains. If I use the display port of the 660gtx ( with a dp-dvi cable) to connect the main monitor sould solve the problem? I think that there is an issue about the type of the dvi cables I use (dvi-i, dvi-d, single or dual). Before a while, I was using a nvidia 550 gtx with the same problems. Can you fix it? Thanks!
    New Friend:
This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Posted on Nov 21, 2013
Testimonial: "I use 2 samsung 2232 bw. I don't know how old are they, the maximum resolution is 1680 X 1050 at 60 Hz. When I swap the 2 cables, the problem remains. It is not the cable itshelf, I have tried three different dvi-dvi. I think if I could use the dp (display port) of the gpu with a dp-dvi cable to connect the primary monitor instead of using the dvi-dvi solution.Do you know if this setup works? I mean using the dp and hdmi ports of the graphic card instead of using the 2 dvi ports? Thanks !"
El Duderino
  • 47 Answers
SOURCE: Dual monitor problem
I've heard this card will support dual monitors but might need a firmware upgrade to do so. You can get the new BIOS here; http://www.gigabyte.com.tw/Support/VGA/BIOS_DownloadFile.aspx?FileType=BIOS&FileID=12292 Hope this helps. Let me know. Dudester
Posted on Nov 16, 2006
babb
  • 104 Answers
SOURCE: Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Posted on Apr 28, 2007
sosa28
  • 53 Answers
SOURCE: geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Posted on Nov 26, 2008
  • 254 Answers
SOURCE: setting up dual monitors with vista
1.both monitors work in single mode ok.
when you start the nvidia contol panel under the display heading
you have setup multiple displays. What does this say.
are you using the nvdia drivers or the cards oem drivers ?
plug one monitor in then start the computer when that monitor works ok , turn off and plug in the other ...
hope this helps
Posted on Dec 31, 2008
  • 9 Answers
SOURCE: XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Posted on Jan 05, 2009
LCD TV display shows pink flickering screen when using DVI > RGB cable
it's easy man when it shows u the walpaper it'sin the extanded desktop so it only shows u a part of the desktop while the other is on ur pc monitor
u need to go whereu can change the resolution and mark the selection *make this as main screen * for both vga and lcd tv done u will have clone desktop on both
Feb 09, 2013 | Nvidia Computers & Internet
I can't connect an external HF199H monitor, on a 2007 MacBook 3,1 running Windows 7. Help??
ok so for clarification, you are using a MacBook w/ a dual boot to windows 7 Ultimate? and after the update from Vista it now is not detecting your external display.
If I am correct, your graphics card is most likely an NVidia chip set. Do some research and find your specific graphics card, go to the NVidia website and download the most up to date drivers for it and try again. If you have done this already, try emailing them and find out if your graphics card is compatible w/ windows 7 or if the driver was specifically designed for vista. That's where I would start.
Jul 03, 2012 | Hannspree HF199H 19 Flat Screen LCD...
I have HP Pro3000MT, and it has vga and dvi port. I want to use dual monitor for this pc. the monitor are HP LCD and it only has vga input. first i use vga port, secondly i use this dvi cable to connect to...
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Apr 01, 2011 | HP SmartBuy Pro 3000 MT Pent Dual Core...
I have a strange problem. Using Windows 7 and Nvidia 260 GTX video card. I have a 20" Samsung syncmaster & a 32" Samsung LCD TV 1080p. I want the Syncmaster to be Monitor 1 & the LCD to...
Windows 7 has some neat little enhancements, one of them being how it lets you handle dual monitors. If you're adding a second monitor to your Windows 7 home or office PC, which is a very good idea, it's a breeze to configure.
There are actually two ways you can currently setup multiple monitors in Windows 7, either by using a keyboard shortcut or via the traditional system properties.
I really like the first method since it's new and is way easier than having to go into the Control Panel or anything else.
Simply press the Windows key and P (Windows + P) to bring up a quick menu of options.
Pretty neat! You can pick to show only the computer, make the second monitor a duplicate of the first, extend the desktop to the second monitor or turn off the first monitor and activate the second.
The second way is to right-click on the desktop and choose Screen resolution.
Now you'll see the familiar 1 and 2 to distinguish which monitor is which. There are several options and under Multiple Displays, you can choose from the same options as when you pressed Win + P.
That's it! You can also change the orientation of the displays and change the resolution of each display. It's pretty straight-forward in Windows 7 and a lot easier! Enjoy!
Dec 31, 2010 | ASUS NVIDIA GeForce 260 GTX,, PCI Express...
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
Nov 24, 2010 | Computers & Internet
Trouble with Samsung 2233RZ
The same to me
I think the monitor is broken
Sep 06, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Setting up dual monitors with vista
hope this helps
Dec 31, 2008 | Computers & Internet
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
111 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
