Question about Toshiba E-studio 3530c Color Copier. Network Ready Print-scan
Toner near empty how do i fix this? - Toshiba E-studio 3530c Color Copier. Network Ready Print-scan
2 Suggested Answers
MedManHelp
  • 55 Answers
SOURCE: my Toshiba toner near empty, but i replace already.Now it is display toner near empty k
Go to job status, press the TONER tab, press REPLACE TONER CARTRIDGE. answer yes. Then replace the TONER cartridge. Press FINISH.
Posted on Jul 21, 2016
My Toshiba toner near empty, but i replace already.Now it is display toner near empty k
Jul 21, 2016 | Toshiba E-Studio 456 Copier
All four toner lights blinking
it could be that you need to replace all the toners. I do not own this kind of printer, but if it is the same as my inkjets, you have to replace all empty cartridges or it still wont work. try replacing the other toner and see what happens.
Nov 08, 2013 | Konica Minolta Magicolor 1600W Printer
Error low toner canon mf5870 nd
> low toner
It means that the toner-cartridge, which holds the dry toner-ink, is nearly empty.
Remove the toner-cartridge, and gently roll it from side-to-side -- DO NOT SHAKE IT.
Replace it, and use it, until it's completely empty. Then, buy a new toner-cartridge.
Jun 06, 2011 | Office Equipment & Supplies
Canon photocopier iR2016 displaying "waste toner full" on screen. How do I fix this?
Hi there you can empty the waste toner box wich is located inside drum unit.
The procedure is next:
open front cover and leftsideway door
release the blue handle above the drum unit
pull out the drum unit
on top of drum unit, near handle is located plastic grey colored cork
remove it and by means of vacume cleaner clean the vaste toner.
Note that if you flip out the drum unit and try to empty waste toner it could be messy and the toner can get into charge roller or on drum cleaning blade and then you need to change it completly.
hope that hepls
Aug 16, 2010 | Canon iR 2016i Black and White Copier
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
On bro copier mfc 3240c printer will not copy with only black ink full and magenta empty and others near empty. will copier not wk if all are not replaced when empty or near empty???
check with brothers tech support to see if you can set the machine to use black toner only... if not then you have to replenish all the empty or near empty toner cartridges...
Dec 18, 2009 | Office Equipment & Supplies
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Waste toner near full?
You can empty the waste chamber on the image unit by removing the screw from both ends of the unit, pull the ends off and empty it out. It's a messy job so have a good plastic bag and a toner vacuum if possible. The message might stay on awhile but will disappear with time. The alternative is a new image unit.$$$$$$
Apr 14, 2009 | Office Equipment & Supplies
Gestetner 3245 (used toner case nearly full)
most likely it will be on the right rear. look for a door w/ a couple of screws, there is a white plastic container, empty or replace and put back. should clear on it own when done.
Sep 26, 2008 | Office Equipment & Supplies
Toshiba E-studio 3530c Color Copier. Network Ready Print-scan Logo
16 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
