Question about Biostar P4M900-M7 Fe VIA P4M900 Socket 775 mATX Motherboard w/Video & Audio
Onboard sound lost after video card installation
Onboard sound is lost after install of ATI video card with DVI connector. No sound connection on Video card. No option to "enable" sound on MB through BIOS. Only Bios options are "auto" and "disable". Video card is:Hp 5188-1678 RV370XT Video Card http://www.ascendtech.us/hp-5188-1678-rv370xt-video-card_i_vcrv370xt256vtd.aspx Best driver I could find for XP pro is "ATI Radeon X300/X550/X1050 series. Is this correct driver? How can I get onboard sound back? Thanks.
    New Friend:
If your PC had an onboard video card before this, you may want to go in and make sure you have disabled it in the BIOS. This has happened to me before.
Posted on Nov 21, 2013
I have issues with the second ATI FirePro V7800 card. I am running Window 7 pro - 64 bit. The motherboard is ASUS Sabertooth X58. Intel Corei7. Corsair 24 GB. Both two cards were working fine...
In order to further troubleshoot this issue, I would recommend the following:
Uninstall the ATI drivers from your computer.
Shut down the computer.
Remove the ATI card from your computer, and connect your monitor to the onboard video adapter.
Turn on the computer.
Ensure the ATI software was infact removed.
Reinstall the ATI video Card
Turn On the computer
Reinstall the ATI drivers ensuring to select the proper "CrossFire" configuration
May 21, 2011 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
When i connect my graphics card to my pc i get a black screen there is no beeps and i cant even hear an windows sound. when i disconnect my gpu my pc works fine i have tried to disable onboard graphics...
Hello xvanpersiex, these are "Full Specifications" of your [Graghis Card].
"Check this to the 'Specs' of the "Motherboard to see if it 'Supports' the Graphic Card?"
"Try 'disconnecting, and reconnecting' the "Graphis Card"
Verify that 'all' the "Connections" are "Tightly Inserted."
*Go to the Control Panel > Device Manager > AGP Graphic Card > Verify Installed? >
Update Driver! > Restart Computer"
"If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9"
ATI Radeon X1650Pro (AGP 8x, 512MB) General
  • Device Type Graphics adapter
  • Enclosure Type Plug-in card
  • Vista Capability This graphics card is capable of running the new Aero interface featured in Windows Vista Home Premium and higher.
  • Interface Type AGP 8x
Processor / Memory
  • Graphics Processor / Vendor ATI Radeon X1650 Pro
  • Graphics Card Performance This card's graphics processor and memory mean that it is not recommended for most games, but it will still be fine for office applications and other normal computing tasks.
  • RAMDAC Clock Speed 400.0 MHz
  • Video Memory Installed 512.0 MB
  • Technology DDR2 SDRAM 128-bit
  • Features Avivo Technology
Video Input
  • Type None
Video Output
  • API Supported OpenGL 2.0,
    DirectX 9.0
  • Max Monitors Supported 2.0
  • TV Interface HDTV out
  • Analog Video Format S-Video,
    Composite video
  • Digital Video Standard Digital Visual Interface (DVI)
Expansion / Connectivity
  • Interfaces 1.0 x DVI-I (dual link) - 15 pin HD D-Sub (HD-15),
    1.0 x HDTV output - 29 pin combined DVI,
    1.0 x VGA
  • Compatible Slots 1.0 x AGP
Miscellaneous
  • Microsoft Certifications Certified for Windows Vista
Software / System Requirements
  • OS Required Microsoft Windows XP,
    Microsoft Windows XP Media Center Edition 2005,
    Microsoft Windows XP 64-bit Edition,
    Microsoft Windows Vista
  • Recommended Power Supply 350.0 Watt
  • Peripheral / Interface Devices CD-ROM
Feb 22, 2011 | ATI RADEON X1650 Graphic Card
Running Windows 7 Home Premium, recently tried installing Radeon X1300 AGP video card, and computer won't display anything or boot with it installed. With card unplugged and using onboard video it still...
Hi - I believe you might be suffering from one of two (or even both) problems. The video card sucks lots of power and I believe has a separate power connector on the card that should be connected. The type of connector varies with manufacturers; from a four pin floppy disc type to a molex type connector or even something proprietary.
Secondly -- It's recommended that you have a 350 watt or higher power supply in your system.
Either issue could keep your machine from booting.
Good Luck, Mikeywaf
Dec 21, 2010 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
Once i connect my gt5662 to a monitor nothing is on the screen, i know the monitor is in fine condition, i realize the graphics card it came with has 2 different slots, should i buy an adapter an hook the...
Did the computer boot to a monitor before? Is this a new monitor for this computer? The GT5662 came with an ATI Radeon HD2400 PCI-e video card. There is also an onboard VGA port on the back of the computer. The VGA port should be disabled. The ATI Radeon HD2400 PCI-e video card comes with two DVI connectors. With the back of the computer facing you, you would use the one on the right. You would have to have an DVI to VGA adapter to use them unless your monitor has a DVI connector also. Hope this helps. This is what the VGA and DVI connectors look like. _498.jpgmoz-screenshot.png
Dec 13, 2010 | Gateway GT5662 Desktop PC
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card...
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Oct 27, 2010 | ATI RADEON 9200 Graphic Card
Dell gx280 wont run I installed new video card in pci e slot
I had exactly the same problem on my friends Dell GX280. It will only let you use the onboard card or the new radeon card not both together. In the end we had to buy a Radeon card that was made specifically for two monitors and disable the onboard card on BIOS. It would not let us use the two seperate cards in unison.
May 06, 2010 | Dell OptiPlex GX280 PC Desktop
Instaled my ati 1650 but monitor does not work
make sure you got a vga to dvi connector or else if you were using onboard graphics before you will need to disable onboard graphics in your bios setup
Jan 26, 2010 | ATI RADEON X1650 Graphic Card
Ati readon 2400
For this operation, you will need to power off the PC and connect your monitor to the ONBOARD graphics connector on the motherboard. While you have the PC powered off, unplug the PC and remove the newly installed card and reboot.
Download and install DriverSweeper, save it to your desktop.
http://downloads.guru3d.com/Guru3D---Driver-Sweeper-(Setup)_d1655.html
Reboot into SafeMode and run DriverSweeper selecting ONLY the drivers that are ATI related but NOT your chipset drivers. If you had an Nvidia card previously installed, you need to select those drivers as well.
After that is complete, restart the PC into normal mode and THEN power the PC off completely. Reinstall the ATI 2400 and hook up the VGA cable to it.
Reboot the PC but within seconds after you press the power button, start tapping the F2(or applicable key) key to access the BIOS. In the BIOS ensure that the Video is set to the proper interface AGP or PCI-express but NOT onboard.
Then go here to download Omega Drivers.
http://www.omegadrivers.net/ati.php
Just follow the prompts and good luck.
Jul 07, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Monitor goes black after windows boots up
Try removing the video card, and look up your motherboard / system manual on dell's website on how to manually reset the bios.
1. Remove video card
2. Reset BIOS (physically opening the computer and using a special jumper and/or removing the battery...what ever the manufacturer says to do to reset the BIOS).
3. After BIOS is reset, try booting up via your onboard video card first. Once you get that working, go into the bios settings and make sure it is set to boot the onboard only for right now and then you can make sure the ATI software is fully uninstalled when you get into windows.
4. Reinstall the ATI card and boot up with the video still connected to the onboard card. See if it will let you install the driver.
The trick here is to reset the bios and get the system booting off the onboard card if at all possible. If that works, then you can always reinstall drivers and then tweak the bios to boot off the AGP card instead of the onboard.
May 01, 2009 | Rosewill RADEON 9200LE (128 MB) Graphic...
Need help disableing onboard video, and installing PCIe video card.
Hi rebelel1271, I do have the manual for you're Intel motherboard. You can have it as well. Click on the link below to download you're manual. document.write("D101GGC Product Documentation & Manuals") D101GGC Product Documentation & Manuals
Intel states you do not need to make any bios changes when you add a PCI-Express video card. See this on page 17, PCI and PCI Express Auto Configuration. Before installing you're PCI-E video card, open windows controll panel. Than open add/remove programs. Look for the driver software for you're onboard ATI Radeon X200. Uninstall that software. (If listed). Close all opened windows & shut down windows. Unplug the power cord from the PC. Open the case. Install you're new ATI Radeon X800 PCI-E video card. Double check all internal connections, (In case you may have bumped loose any cables). You're X800 may also have a 3-pin or 4-pin male power connector built on the card. If so, plug power to the X800.
Intel D101GGC driver page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DOC
ATI's web site for the latest driver's.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
A little information. Once you're PCI-E has been installed. You're system memory will increase.
Good Luck!
If I can help you further, feel free to post here.
Mike
Jun 01, 2008 | Intel D101GGC Motherboard
Biostar P4M900-M7 Fe VIA P4M900 Socket 775 mATX Motherboard w/Video & Audio  Logo
98 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
