Question about Vision Fitness T9200 Simple Treadmill
T9200 simple belt moved and is bunched in center
The belt on my machine move last week and i thought i had adjsuted it. it worked for 2 days (one hour) then this morning it suddnel moved right and is bunched in the cneter of the belt how do i correct this
    Top Expert:
  • Vision Fitness Master
  • 12,223 Answers
Please follow this steps and fix it. GOD BLESS YOU
Posted on Nov 22, 2013
Treadmill bunching up
running belt has bunched up in the middle
Jan 19, 2014 | Vision Fitness T9200 Treadmill
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
I have a singer simple and within only seconds of sewing, the bottom thread will have bunched up 10 times of the amount of thread I would have thought I even used on the bottom side of the fabric
It is in your top threading. Rethread, and with the presser foot up, pull the top thread, it should feed smoothly, now put the presser foot down, the thread should barely move. This should seat the thread in the tension discs. Good luck
Dec 10, 2010 | Singer 3116 Simple
Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
Nov 25, 2009 | Reebok Vista Treadmill - RBTL13305
How do I change the battery on a 1994 volvo 850
Don't know about the layout of the Volvo belts; however, there are basically two ways to release and restore tension on belts.
The old way involved components that could be moved in and out to allow the new belt to be put in place and then have tension restored to the belt. A bolt in an elongated hole allowed this movement. The component that could be moved could be the alternator or power steering pump. The sequence was: loosen the bolt, move the component, install the new belt, move the component back till the belt is tensioned, and tighten the bolt.
The new system involves a tensioner that holds the belt in position. These tensioners can be moved in one direction to allow the new belt to be installed. After the belt is in place, the tensioner is released and it moves back to a position where it keeps the proper tension on the belt.
Oct 20, 2009 | 1994 Volvo 850
Blurry edges
I own the same model of tv and have owned it for over 1.5 years. I moved with it twice. I had this problem about a month ago. On both vertical sides the screen became very fuzzy, yet the center remained clear. When turning the tv off and on I also noticed very wierd red, green, and blue lines streaming across the screen before the picture comes up or after it fades. I found no solution or cause to the problem. But I had two "long-boy" speakers from my panisonic 5.1 surround sound system setup right next the tv on either side. I set the center channel on top of the tv with the receiver on the shelf below. I thought well maybe some how the speakers were cause some sort problem in the tv. I moved the side "long-boy" speakers from directly next to the tv to about 6" away and removed the center speaker from the top of the tv. After several days of normal use of this configuration, the tv turned like normal and the fuzzy edges were gone. The symptoms lasted for around two weeks, and the several days after I moved my speakers. My only guess is that without a deguassing feature, it took several days for the magnitism to return to normal after repositioning my speakers.
Mar 17, 2008 | Samsung SlimFit TX-S3082WH 30" TV
My maytag atlantis won't spin just makes noise
The transmission has a very poorly made gear with 2 tabs on it in center- botton of the transmission inside these tabs break off then it won't spin, i got 2 0f them here now and no part to fix them with , Maytag should made supply the part to fix it with, they want to sell you a whole transmission at better that 200.00 , Jimmy T.
Jan 17, 2008 | Washing Machines
Squeeking sound
Sounds more like the brake assy. is sticking.
On the top shaft you will notice there are to moving shoes. These shoes are what start and stop the transmission spin capabilities. Either the shoes or the drum service needs to be serviced and possibly replaced.
Jan 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Intuitive washer code 43
Thx to fixya l sovled my code 43 by removing and cleaning my balance control switch. If anyone needs to know here step by step
1 Make sure the plug is out ( dont want curly hair do you )
2 Remove 2 screws from back of control panel and lift off
3 Remove 1 screw holding grey module panel
4 Under grey module on right hand side is the balance control switch with 1 white and 1 yellow set of wires
5 remove wires ( make note on where they plug back into )
6 2 small clips hold the switch in place, open them gently and pull switch out
Its that simple , clean the contacts with some wd40 or bicarb soda in hot water to get rid of any corrosion, make sure that the little button on the side springs out freely ( tiny drop of oil/wd40 ) clean or replace plugs on the white / yellow wires. install and do that washing!!! It worked for me but if the switch is too far gone no need for a service man just get a new one and go for it .
Good luck Pieman
Oct 06, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Vision Fitness T9200 Simple Treadmill Logo
107 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
Don Eagan
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
