Question about Cameras
Flash not working on s1000
We have popped open the flash and it does not work. It shows a circle with a line across the flash sign. I am not sure how to correct this. I have tried everything I know how to do manually.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
One thing you could try is telling us the maker of your camera. At least three companies make model S1000 cameras.
Posted on Nov 21, 2013
4 Suggested Answers
Kimi
  • 277 Answers
SOURCE: Flash pops up but does not flash
Turning the Flash Off and On: 1. With the camera in any user set, repeatedly press the Flash/ISO button on the lens barrel until the flash cancel icon (a lightning bolt in a circle with a slash through it) is displayed on the control panel and screen. 2. When finished, to return to the default setting, press the Flash/ISO button until AUTO and the lightning bolt icon are displayed on the control panel and no flash icon is displayed on the screen. If it still doesnt help: 1. Check that batteries are fresh. 2. Check that camera hasn't been set for no-flash mode. 3. Give the flash time to charge before pressing shutter.
Posted on Sep 07, 2005
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
SOURCE: Sony DSC-F828 Faulty Flash
Try resetting the camera. It is next to the battery release. I had a similar issue and posted help. No remedey. So, after praying about this issue, I was lead to power it down and eliminate all the power by taking out the battery push the power button and many others. I found the reset button pushed it and it is all working now. The praying for a solution was key. Praise Jesus. DRD
Posted on Jul 03, 2009
Why won't d5100 flash won't pop up?
It won't in several shooting modes, like manual. Try auto and make sure flash mode is not set to off (circle with line over lightening bolt) but to auto.
May 13, 2014 | Nikon D5100 Digital Camera with 1855mm...
My nikon D-80's flash won't pop up, yet it also won't go past the flash sync speed of 1/200 while flash is down
Was the camera impacted? Sound like the flash up switch if always closed. Remove battery. If you carefully remove the flash cover (two screw underneath) by first inserting a business card under the flash on the rewind side (yeah, we haven't come up with a better term!) at the back and slide it forward freeing the flash down latch), and do not touch the flash tube as there is 300 + volts across it if it is charged!
Look at the pivot for the flash on the release button side at the back, you will see a small switch. the top part may be under the activating rod - reset it above the rod and it will now work properly
Once again, be careful - there are 300 volts across the flash tube if it is charged
May 06, 2012 | Nikon D80 Digital Camera with 18-135mm...
My nikon d90 pop up flash is not working but the pup up is poping up
Hi Reggie,
Usually the pop up flash will extend when the program calls for it or the user has manually turned it on, and it will fire without an issue. Page 70 of the manual goes into detail how it is set up and uses graphics which won't work very well here. Unless you have the "circle with a line though it" over the lightning bolt "flash" symbol, the flash should fire when needed.
It is possible that the flash lamp has failed, and may need to be replaced. Contact Nikon Service & Support or other reputable camera shop to help you with that.
I hope this helps & good luck!
Mar 24, 2011 | Nikon DSLR D90 Digital Camera
How do I disable the pop-up flash on Nikon D5000? Thanks
As long as jog dial is set to M or manual, the flash will not pop up automatically. Be reminded though because you have to set everything manually. If you want the auto settings without the flash, set the jog dial to the icon that looks like a lightning with stop/ no sign
Mar 02, 2011 | Nikon D5000 Body Only Digital Camera
The flash will not work. I think something needs to be reset but not sure how to do that.
On the Navigaton direction button on the back of the camera the "Right direction" button has a little lightning bolt sign.
Repeatedly press this button while the camera is in picture taking mode to go through the flash settings sequence. (Watch the display while pressing this button)
Settings:
1 No Flash, Lightning bolt circled with slash across it.
2 Auto Flash, Lightning bolt with an "A" beside it.
3 Auto RedEye remover, includes an "eye" symbol.
4 Flash Always On, Lightning bolt alone.
5 Unknown, I don't know what the S mode is, I haven't used that one before (something to do with ISO virtual film speed setting).
Have fun.
Jan 18, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Err 99 when use internal flash
There is a Canon Help line on the Canon web site which will help you. They are excellent
Jan 19, 2009 | Canon EOS 40D Digital Camera
E91:01 Constant flash sign on Cybershot DSC-W80
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Oct 29, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Problem with Flash in FZ8
In your menu's look for the entry named "conversion" make sure that it is "off" it seems when this mode is on, flash is forced off.
Nov 18, 2007 | Panasonic Lumix DMC-FZ8 Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
