Question about Samsung Cell Phones
Can't unlock my phone and it requires a google account
I can switch on my phone but the time it's ready it asking for google account
    Guru:
  • 352 Answers
You should be able to bypass setting up or adding a google account, and go straight to using your phone. there is probably a set up later or cancel button on that screen. google accounts just help sync up apps, contacts, and other data from the cloud to your devices.
Posted on Nov 21, 2013
SOURCE: too many pattern attempts
there's an actual android bug here as well, even if you haven't forgotten your credentials. see comment 93 or 127 in http://code.google.com/p/android/issues/detail?id=3006
Posted on Feb 25, 2010
  • 41 Answers
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
  1. Remove and reinsert battery.
  2. Press Volume down, Send, and End keys until reboot option pops up.
  3. Scroll to wipe data/factory reset, then press OK.
  4. Press Volume up to hard reset the phone.
  5. With reboot system now highlighted, press OK to reboot the phone.....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
Posted on Apr 26, 2010
Mykel_N
  • 315 Answers
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , john123@gmail.com. Now this google id on the top right corner of the page would be displayed as john123@googlemail.com
3) Type in the google id, thats visible on the right hand top corner of your page (like john123@googlemail.com) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
Posted on Oct 12, 2010
  • 90 Answers
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset) If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on. Note: Factory reset will not remove the data and files that are in your phone's microSD card. Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset. Performing a factory reset using phone buttons If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button. Note: If you are not sure whether your phone's power is turned off, remove and then reinsert the battery.
  2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Posted on Mar 27, 2011
SOURCE: Micromax A27 Google Account & Pattern Unlock done
A 27 TOO MANY PATTERN SOLUSION
Posted on Jul 09, 2013
How to bypass google account on zte blade a112lte with a older os i think as all tutorials i have found dont work. I had to reset my phone due to a network error. I have done a back up to my sd card.
Googles' Factory Reset Protection FRP
Googles' Account Verification
Googles' 72Hour Lockout Security
When Hard Reset (with phone Off) Or
Factory Reset (through settings menu) is Performed on any Google accessible smart phone, while User Account is Logged in to phone, and AlSo With Account Recovery Active, Then Google Requires "LOGIN WITH ORIGINAL USER ACCOUNT PASSWORD"
But Then You Dont Remember PASSWORD OR GMAIL.
Ouch......Bummer
No One Wants to Be LOCKOUT of there phone,
HOW TO GET PASSED
GOOGLE FACTORY RESET PROTECTION
ACCOUNT VERIFICATION and 72 HOUR LOCKOUT
  1. On your phone, On the ENTER Account SignIN Page. There is an option to CHANGE PASSWORD.
  2. IF You Have Already Tryed This, GOOD.
  3. YOU ARE One step ahead.
  4. CLICK CHANGE PASSWORD
  5. CAN YOU REmember recovery Email or Number?
  6. You will Be sent "VERIFY CHANGE PASSWORD" email or text.
  7. Were You Able To Change Password?
  8. IF YES, Awsome. DO NOT FORGET NEW PASSWORD skip to step # 18.
  9. IF NO, YOU were Not able to change password.
  10. IF NO YOU were Not able to access Verification email
  11. There is Three Options you have to Unlock Your Phone.
  12. ONE.......TAKE 40$-60$ AND YOUR ZTE to a Mobile Phone Repair Shop.(Boost Mobile Repair, 40$ 2hrs unlock all passwords, you have access to your phone) ***This Option Worked For You, Congradulations!!!!***
  13. TWO.......You can do the same thing the Phone Repair Shop Does at Home, There are a Few Things You Will Need.
  14. ACCESS TO A Personal Computer (Laptop, Friends Computer, Moms Computer will work Too. *(*NO PUBLIC COMPUTER, LIBRARY COMPUTER CAFE*)*
  15. MICRO USB FLASH DRIVE. Is a regular flash drive, 1GB is More than enough empty space. ?MICRO? is two way Cord that allows USB Flash Drive To Also Connect To Smart Phone, Using Charge Input Jack.
  16. Download ZTE LTE Software, directly to Flash Drive.
  17. On ENTER account info page, Connect Flash Drive to Cell Phone. At top of screen, Notification promped askes "Open USB", Open USB>file folder>downloads> zip file>install>download>programs>unlocks phone.
  18. Three.......SKIP TO STEP #30
  19. You were able to Access Verification email. And you still remember password. AWSOME....GOOD JOB.....
  20. This is the simplist way to bypass Google Account VERIFICATION.
  21. So now you are wondering why then new password is not working?
  22. Google also has a 72 HOUR LOCKOUT SECURITY. On the verification Email there is a Time Stamped. The time is your email recieved time.
  23. This time Started Googles' 72 Hour CountDown.
  24. Do not attempt to reset Password, or login again untill countdown has expired. You dont want to chance time Restarting.
  25. If time stamped was 8AM 26th, 72 Hrs is up 8AM 29th. I would wait just a half hour more.
  26. Best thing to do now is Kickback 3 days.
  27. When Countdown has expired, New password will work to log in.
UNABLE TO ACCESS VERIFICATION EMAIL???
NOT GOING TO WAIT 72 HOURS???
NO $$ FOR MOBILE PHONE REPAIR SHOP???
TRY THESE SIMPLE STEPS.
After the phone has finished its factory reset it will reboot and you will be prompted to choose the desired display language.
After choosing the correct language please follow the next steps:
  1. Connect the phone to a Wifi Network (preferably your Home network)
  2. The next screen will ask you for the Google Account
  3. Tap the text field in which the account should be inserted until the Keyboard comes up
  4. Tap and hold the "@" character until a Settings menu pops up
  5. Select Google Keyboard Settings
  6. Tap on the 3 dots in the top part of the screen (or More depending on what Android OS you are running)
  7. Select the Help & Feedback item and select any item in the list that will follow
  8. Long press to select anytext on this page and click on Websearch in the upper right corner
  9. A search field will be shown (delete the text inside the search field)
  10. Type Settings in the search field
  11. Tap "About Phone" and tap 7 times on the Build Number to enable Developer Options
  12. Return to the previous menu and open the Developer Option that just appeared
  13. Allow OEM Unlocking and tap Back two times
  14. Restart the device
  15. Connect it to Wifi again
  16. Notice how you won't be prompted to log in the previous Google Account and instead the phone will ask you to ADD a new Google Account.
Jos
?'s & Commentz.....
Mar 26, 2017 | ZTE Cell Phones
Too many pattern attempts, i to unlock my phone
I please want to unlock my phone. I was asked to sign in with google account in order to unlock my phone. I have tried this to no avail
Nov 25, 2013 | Sharp FX Plus
How to unlock samsung galaxy y (GT-S5360).to many pattern attemps
I forget my unlock pattern code and now asking the gmail addres
Oct 28, 2011 | Samsung Galaxy S GTI9000 Smartphone
Forgot my password to unlock home sreen on my Samsung Infuse 4G Smartphone is ther a master reset code for the home sreen?
Hello, you can use your google account to unlock samsung infuse screen pattern, just try any pattern for 5 times then your phone will be asking you to input your google account. But if you never setup google account in that phone you only have one last option to unlock samsung password by doing hard reset. You can read in your manual book how to hard reset your phone.
Oct 16, 2011 | Samsung Infuse 4G Smartphone
I forget my screen pattern code how can unlock the screen pattern code with out re setting LG optimus 500 if it does not work . can I do factory reset and how thank u
You can unlock LG p500 screen pattern using your google acount, but if you already set it in your phone. To unlock lg phone with google account you just need to type any wrong pattern 5 times then your phone will be asking your google account and after you insert that google account you can setup new screen patern for your phone. Unfortunately if you don't ever setup google account in your phone, you only can unlock it with factory reset methods. For the details about this process you can see at here at page 21 and soon. I hope my solution can solve your problem.
Sep 13, 2011 | LG P500 Cell Phone
I got my pattern code wroung on my samsung galxy 19000 now its lock
Get your account password wrong 5 times and it will ask you if you forgot your password at the bottom. Then it gives you the opportunity to unlock your phone using your Google account credentials.
Mar 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
Used wrong pattern to many times now asking for my google account and i cant remember it,how do i unlock phone
Go to: http://www.google.com/accounts and click on the "Can't access your account" link in the login box. If you set up any account recovery methods, you can use them to get your password and unlock your phone.
If this helped, please give me a few thumbs up and leave a comment, thanks!
Mar 01, 2011 | HTC Wildfire Cell Phone
Cell Phones Logo
107 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
