Question about Dell Dimension XPS 400 PC Desktop
Monitor screen is black but computer seems to work
    Problem Solver:
  • 17 Answers
That is not enough info, please provide more info so people can understand the issue better. For example, describe what you do and see step by step. When you turn on the machine, after a few seconds it powers on, it should run Power-On-Self-Test (POST) which will end with a beep telling you everything was OK. If you do not hear any beep, the problem is likely to be inside the case, bad video card, motherboard, CPU, etc. Typically bad RAM or Video card will cause a series of quick or long beeps (different for each motherboard) to indicate where the problem is. Bad CPU generally do not generate a beep code and most motherboards also do not give out a beep for motherboard issues, naturally.
If you hear that beep but see absolutely nothing on the screen from the moment you turn it on, then check to see if the status indicator light (assuming it has one) changes color or not:
A) If the light on the monitor changes from red/amber to blue/green but you see nothing on the screen then either the video resolution and/or refresh rate is unsupported, video drivers are faulty or monitor itself is bad.
B) If the light goes back to red/amber or stays that way from get-go, then there is no connection, monitor cable is loose at either end or bad/supported.
C) One other possibility would be the input selection on the monitor which is set to "Auto" by default but if it was manually changed to DVI for example and you are now using a HDMI cable, monitor would not automatically change this setting thus not receiving the signal from the video card. You can check this using the menu buttons on the monitor itself.
This is a generic troubleshooting ideas I just shared, more details you can provide, the better people will be able to assist you.
Posted on Nov 21, 2013
    Problem Solver:
  • 21 Answers
Check the video cable.if not restar the computer and keep pressing F1 (for windows7) then select VGA MODE ...
after it will come, you've to check the resolution of your screen.put it in 1024X768
Samsung SyncMaster 2232gw unstable
It seems from the begining you have had nothing but trouble, if under warranty return the item, because it will eventually fail, it is a matter of probability.
Apr 22, 2012 | Computers & Internet
Lenovo u260 screen black
Switch back to internal monitor in bios setup or do both internal and external monitor.
Feb 11, 2012 | Lenovo IdeaPad U260 Laptop Computer -...
Computer was working, then the monitor went black and the yellow lights keeps flashing. The screen also seems to be pulsing. Whats wrong with it?
Have you tried another monitor??
If stil no go then may be video card.
I do not understand "the screen is pulsing"
Jan 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Acer Screen goes blank when fan comes on...Help!!!
Hi...there,
It's seems your backlight inverter are busted. Need to replaced a new one...
Nov 27, 2008 | Acer AL1511 15" LCD Monitor
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
Monitor suddenly goes black
Is this monitor and LCD flat Panel? If so this is due to a bad power supply, an inverter board going bad or LCD backlight bulb blown. When the backlight goes bad it gets just enough power to start up, but when it is on for a long period of time it goes black because the bulb is not stable enough to hold the charge because it is going bad. These bulbs can be changed, but they also can be costly!
Nov 17, 2007 | LG L1930B 19" LCD Monitor
Viewsonic VA712b 17 " flat screen monitor
Realheadache, Unusual problem, it could be the resolution and refresh rate setting your PCs video card is currently set at. I don?t know if this will fix your problem but its worth a try: - Now go to your PC with the old monitor connected, right click anywhere on the desktop. - Left click Properties from the box that appears. - When the Display Properties box appears click on the Settings tab. - Make note of the screen resolution. - Change the screen resolution to 1024 x 768. - Click on the Advanced button in the lower right hand corner. - In the next box that appears click on the Monitor tab. - In the Monitor settings section of this page record the value of the Screen refresh rate. Then change it to 60 Hertz. - Close this and the Display Properties box by click on the OK button. - Now try connecting your new monitor. Let us know if this helps and as always please don?t forget to rate this posting.
Feb 04, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Dell Dimension XPS 400 PC Desktop Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
