Question about Furuno 000-631-716 Carbon Brush for D8G-516 Motor EACH
Carbon Brush for RM 7398 Motor - Furuno 000-631-716 Carbon Brush for D8G-516 Motor EACH
My belt is lubed and properly tightened. The belt will slow down intermittently randomly while running without anyone on it. Model NTL2495.0
first of all check the drive belt is loose or not. Drive beit connect with the motor and roller of the treadmill. its not possible to see the drive belt out side. you can only see it if you remove the motor cover. if its loose the try to tighten it. if its not the problem then the treadmill motor have some problem. Either the motor is faulty or the carbon brush is faulty. There is 2 carbon brush inside the motor which is replaceable, its used to take the voltage to the rotary part (armature) of the motor. If the contact with the rotary part and carbon brush is poor the this type of problem can occur. tyr to change the brush. Here i have added a video which demonstrate how to change the carbon brush of the treadmill motor. It not the exact model you have. but almost all treadmills have the same type of motor. even after replacing the carbon brush the treadmill shows the same problem then you have to charge the motor with a new one .
http://electro-medical.blogspot.com/
Fitness repairs
Nov 13, 2015 | Exercise & Fitness
Where we buy Samsung Washing Machine replacement part i need a (motor carbon brush) Model for WF-B1061
samsung authorized repair shop spares
go google to samsung spares direct
find an appliance repair shop as the motor may be generic or have generic brushes fitted
Sep 30, 2015 | Samsung Washing Machines
Flashing on carbon brush, even after replasing field coil, armature and carbon brush.
Check for a weak/collapsed spring on the sparking brush. Also check the brush holder for any interior debris which might impede proper brush movement. Do both brushes spark? There should be a fine line of spark at the brush contact to the commutator normally. Make sure the motor tuns easily, as a bad bearing can cause sparking due to overload conditions. Hope this helps!
Feb 09, 2011 | Garden
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
Rear wheel sticks and sometimes when you go to go forward nothing l of a happens,then al of a sudden it jurks forward with no warning.l
Hi. Sounds like you have worn out motor brushes. the brushes wear down to short and get stuck in the brush holders. Sometimes the caps that hold the carbon brushes in come loose, and the carbon brushes get stuck because the current arcs between the carbon brush and the brush guide. Get a serviceman to overhaul the motor, and it will work fine. Probably a good idea to replace the motor bearings at the same time. Good luck. Neil.
May 27, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Need carbon brush replacments
google for sources. In the 80's i was employed by a co that probuced brushes according to specs. We received them in bags, or envelopes, etc. If you cannot find them through the orig. mfgr., send the remaining brush or the holder, with as much of the brush as is remaining for proper dim. estimate and brush composition. some brushes have the composition of dry charcoal. while some such as "EGO" can substitute for a very soft pencil.
Nov 26, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The foot control is not working
well particular on electrical problem foot control is a switch of motor that deliver speed varies on how you press the foot pedal it consist of circular thick plate carbon the old model and the new one electronically control of power ic,It depend on how this pedal was contro.Anyway besure the power is off or unplug the machine; this control was been connected in series connection to the motor which you can test if your foot pedal control is defective. Disconnect the line wire holding foot pedal from the terminal inside motor assembly.If your not qualified electrician don.t do this.Connect the two terminal wire that inside the machine where the motor mounted.This connection is supplying your motor in full speed,Declucth your machine from the handwheel so that the motor run only.Plug the machine and switcn but you must jug only if the motor run in couple second of course without the foot control this was disconnected already.So your foot control is defective vice versa if motor does not run without foot control motor is busted.
how to fix if foot contol is defective, in carbon type you must replcace the circular thick carbon.On Electronic control check the IC if this open or some capacitor and resistor are open,Replaced any pars that had been short circuited.If the motor is defective replaced the carbon brush mounted at two side of motor case,There is an opening port.The carbon brush has spring holding push this carbon brush to the brush armature of rotor.
Mar 06, 2009 | Kenmore Sewing Machines
Blower for AC/Heater stopped working
if you can reach the blower motor, it could be a worn out carbon brush of the blower motor. if they are, buy a set of carbon brush, learn how to replace them and it would be back running in no time. by the way, when you pull out the carbon brush holder, make sure you dont interchange the position. you can put them back wards and what would happen is the rotation will be reversed. either you reversed the carbon brush holder or just simply interchange the wires that are coming to the motor. i hope i was able to help...
Jul 07, 2008 | 2000 Ford Focus
Furuno 000-631-716 Carbon Brush for D8G-516 Motor EACH Logo
81 people viewed this question
Top Furuno GPS Experts
Ron Dufek
Ron Dufek
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
