Question about Philips Cineos HTS9800W System
Coby tv will click like it's going to come on, but it does not. Can up/down sound...yet no sound. DVD player works
2 Suggested Answers
  • 556 Answers
SOURCE: DVD player makes clicking sound but won't play
check for proper connectionor check for playing another dvd. as every things seem to be ok.
Posted on Sep 26, 2007
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
I just bought the coby csp96 surround sound package and am having trouble hooking everything up. It came with the dvd player to hook all the input cords to, which i did. Everything is working accept when i...
there is a nobb on the subwoofer, one is to dial down or up the sub (noob1) , and the other is to dial up or down the 5.1 speark (noob 2). turn noob 2 to the left to dial down the sound, first time i got my setup it was totally down, btw the 5.1 works wonderous if you use a home theater system. Iam using a 1,000watt sony home theater system. 100/200watt RMS per channel at 5 channel those little speakers really can handle well, I never experiance any blow outs :) Coby outdid themselfs with this system
Sep 05, 2010 | Coby CSP-94 Speaker
I put in a blank dvd+R and it will say format on the tv screen and erase on the dvd player screen then when it finished it says no disc
u have to go into disc infor on set up them scroll down to erase an click this yes this will clear the disk
May 25, 2010 | Coby DVD-R1200 DVD Recorder
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
My portable COby DVD player stopped working. DVD rotates when I put it in by screen remains black... With TV out option sound comes out and picture/sound shows on TV once I connect it to DVD
I have had some very bad luck with Coby products and am sorry to hear that you have too but please make sure that the connector jack is clean and functioning properly. The connection jack has a device inside it that knows when the plug is inserted and then sends the audio and video out to the TV. If the connector is really dirty it could be that the connector is not working properly.
There isn't a lot more to look at unless there is some obvious problem with the screen such as a loose wire or a broken hinge.
Feb 26, 2009 | Coby TF-DVD8107 Portable DVD Player with...
Can't program coby dvd 224 help
Shana, What are you really trying to do!!!! Do you understand what the jacks on the Coby DVD player are for?? Can you connect the Coby player directly to TV AUX inputs and play a DVD?
Is the satellite 'box' still connected to TV/Monitor using TV Tuner set to chann 3 or 4? Is the TV you
are trying to use have any or none of those YELLOW/RED/WHITE jacks on the back of it that you
have never plugged anything into them. Is the TV always set to Ch3, and is never changed to any
other Ch number??? Do you only change Ch up or down using the satellite "box" tuner? ALL these
questions and more must be answered by you before anyone can help you out. You must know your
own equiptment and its capabilities. The COBY Player will never be found by the satellite dish tuner.
comments or info send to lmistyrel @ aol.com
louie12fix @ fixya
Dec 26, 2008 | Coby DVD-224 DVD Player
How to restore factory settings for Coby 755 DVD Player
Ok I'm going to walk you through this...
Turn the DVD player on... give it a second to load up
Now Press Setup.. now navigate down 5 times Press Enter
Navigate down once Press Enter... Or it might just be a Press enter I'm reading from the manual. Click here for the Manual
That is the way to get to the factory default button in the setup.. If your having trouble doing that try using the manual to see where to go to get back to the NTSC settings
May 03, 2008 | Coby DVD-755 System
Philips Cineos HTS9800W System Logo
13 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
