Question about Frigidaire 24 in. FDB421RF Built-in Dishwasher
Not draining...hose clear
My dishwasher has been working great for years but stopped draining a few days ago. I have verified the drain hose is clear, air-gap is clear, hose from air-gap to garbage disposal is clear, and the knockout plug in the disposal has been correctly removed. My thinking is most likely the drain pump needs to be replaced. The dishwasher does make a slightly different sound than it used to when it enters the drain cycle. Anyone know of any other diagnosing I can do or other possible problems before I spend the money on a new drain pump? Thanks in advance.
  • 1 more comment
  • mjpalad Oct 09, 2007
    Thanks for the response. I saw an article athttp://www.acmehowto.com/howto/appliance... that talks about testing the pump with a multimeter. Does that seem like a legitimate test?
  • mjpalad Oct 16, 2007
    Just to update, I got a used drain pump from a local used appliance store and that did the trick. It sure was satisfying to see that water start pumping.  Thanks for the input bluegreenash.
  • Anonymous Mar 23, 2014
    We have cleared the drain and removed the hose from the sink. Is there a pump that drains the water. We also made sure garbage disposal was clear and working properly. The drain in kitchen working fine also.
  • 661 Answers
Not really, it sounds like you have done all the basics,
Posted on Oct 09, 2007
I have a brand new Hotpoint (GE) dishwasher model HDA2100H35CC that has not drained since the install just a few days ago. The solenoid can be actuated with no resistance manually, and the armature l
you may have forgotten to punch out the plug on the drain connection where you connected the drain hose to the garbage disposal or drain. best luck to you.
Dec 15, 2014 | Hotpoint Washing Machines
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Dishwasher won't drain. I made sure the sink drain were clear I don't have a Air Gap. Is there a way to check the drain inside the disherwasher. It started a couple days ago
I would check for obstruction in the drain hose.Take the drain hose off the garbage disposer hold it as low as you can over a pan or bucket and see if the dishwasher will drain centrifugally.If it does I would assume the pump is bad or disconnected.Possibly a utensil jamming it.
May 07, 2011 | GE 24 in. Profile PDW7800 Built-in...
Water wont drain, water leaks out of pump and from the front of the dishwasher
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 01, 2011 | GE Nautilus 24" Built-in Dishwasher
Realworld Sicuro RW-670XL 5.1 speakers. The front speakers (L, R) have stopped producing sound. I know it is a problem relating to where they plug into the subwoofer - since I can take any of the...
F4 is typically related to a drainage problem. If the water is not draining from your dishwasher, verify the following: Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall. Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it. Inspect the sump area for any debris or broken glass that could be blocking any ports. Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced. Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it. There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a plumber test it for you.
Feb 16, 2010 | Sicuro RealWorld 670XL-BK 5.1 Gaming...
It give me an code F4 and nothing works the fill valves open for a few seconds and then a buzzer gos off and i get the F4 code
Feb 16, 2010 | Whirlpool GSX9885J Top Load Washer
My Bosch dishwasher SHX46A05UC is not draining
Verify that water from the sink drain is not making it's way into the dishwasher. I would recommend creating a high loop in the dishwasher drain pipe, which is attached to the sink drain, under the sink. The high loop can be fastened to underneath the countertop. This will prevent any water from entering the dishwasher from the sink; it also prevents the dishwasher drain water from making it's way back into the dishwasher
There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a technician test it for you.
Sep 21, 2009 | Bosch Dishwashers
The dishwasher does not drain water
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Jul 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
279 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
