Question about Measuring Tools & Sensors
My chainsaw starts up and the engine is racing works for 30minutes then cuts out
    Problem Solver:
  • 18 Answers
Have you cleaned out the air filter lately? If all tune ups have been done you may be running too lean, there should be adjustment screws to make a bit more rich, you will have to play with it and listen to the sound to get the best results.
Posted on Feb 01, 2014
When go to cut engine is runnig but chain stops when touch the tree
Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
Nov 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Tip
Chainsaw erratic - starts - won't start - dies at steep angle
My chainsaw was erratic. Sometimes it started and ran just fine and at other times it just refused to start or died as I raised it to cut a limb. What I finally realized is that chainsaws are different than other 2 cycles engine devices - they have to work at many different angles (including straight up). For that reason, the fuel filter that is in the gas tank is weighted to keep it at the bottom of the gas tank as you raise and/or lower the chainsaw.
On my Mccullough, the gas line broke right at the weighted filter, allowing the gas line to flop around. That's why it was erratic and died when I raised it to cut a limb. So, if you have erratic operation, take a minute to check your gas filter and be sure it's still attached to the gas line......
on Jan 16, 2017 | Miscellaneous
Husqvarna 65l starts racing after two cuts then cuts out
Hello John , I would suggest you remove the muffler. Between the muffler and the cylinder is a spark arrester screen. Hold the edge of the screen with a pair of pliers and burn off the carbon from the screen with a propane torch. Reinstall muffler and screen after it cools down. I hope this helps.
Mar 12, 2015 | Husqvarna 65 385 395 Hv24-50pa-fb
Does the chain AKE 40/19 fit chainsaw AKE 40/17
no it's gonna be two inches longer . you might be able to change chain and bar between saws ? i never done that might work , but would be down on power with larger bar 4 sure , but still would cut wood , just dont enter it in any races
Mar 01, 2015 | Bosch Garden
Engine racing at idle
some sealing is not correctly installed or is broken- to much air in gas ----
Apr 05, 2014 | Homelite Garden
Engine cut out while driving
any check engine lights or computer codes. also check spark and buy ether and spay it in the air filter. always use caution when using ether and working on a hot engine
Feb 08, 2018 | Hyundai Elantra Cars & Trucks
Model 445 chainsaw. Was cutting all day and no problem. Good gasoline, Husqvarna 2 cycle oil. All of a sudden started racing like the carb was stuck full open even when throttle trigger released. Then...
Engine speeding up on idle is normally due to an air leak, check the carb securing screws are tight, if you have a leaking crank seal it will be a shop repair.
Feb 28, 2010 | Husqvarna Forest & Garden #966906636 445...
Chainsaw starts works for about a minute two mnutes cuts out at high rev
That is the sign of out of fuel, Mine races when it runs out, you must have a clogged up fuel line, Take off the back cover, get the fuel line off at the carb and blow through it. Peek inside the fuel tank and see if there is anything floating around.
Feb 22, 2010 | Husqvarna Garden
Measuring Tools & Sensors Logo
29 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
