Question about Singer 3116 Simple
Thread not coming back up from bobbin - Singer 3116 Simple
    Champion:
    Habit-Forming:
  • 201 Answers
It can be very frustrating if your machine is not sewing properly. This guide is about sewing machine needle not catching thread. And check the needle correct position or bobbin winding correctly . Also try using the same thread in top & bottom.
Posted on Nov 22, 2013
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 6 Answers
SOURCE: Thread catching and bunching up in bobbin latch while sewing
I had the same problem where the thread was getting all bunched up on the underside. I took everything out and followed the manual concerning threading, then manually moved my right wheel to see if it would get bunched up. It took awhile, but I finally got it sew correctly again. I;m still not sure what was wrong with it. I have a singer 7470.
Posted on Mar 24, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
SOURCE: I was given this machine and I can't get the
try these suggestions
Check your needle to see if it's damaged
Make sure you have a 3-5 inch thread tail on both top thread & bobbin
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of machine & slowly lower needle into bobbin area & see if it will pick up the bobbin thread that way
Posted on Oct 08, 2010
SOURCE: needle doesn't pick up bobbin thread
try rethreading the machine -use every thread guide
change the needle--make sure it's the right one for the fabric
your sewing
take the bobbin out & reinsert the bobbin into the bobbin case
make sure the bobbin is turned the right way when inserting it
if these suggestions don't help then the machine need to be checked
here a link for a free manual
http://www.singerco.com/uploads/download/549_7469_efs.pdf
Posted on Sep 11, 2012
Thread is gathering under cloth
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
May 05, 2011 | Olde Thompson PWZ500
When I stitch the spool thread gets bunched underneath the cloth and get stuck underneath, please help
Apr 21, 2011 | Janome 1017 Mechanical Sewing Machine
My bobbin threat is bunching and after a couple of inches, the top thread breaks.
Apr 13, 2011 | Bernina Artista 180
Hi, using a jonome finesse model 356, changed the thread on the bobbin and now its knotting up and not loose from the bottom, did i thread it incorrectly? tension is wrong now?? thanks!
Apr 11, 2011 | Janome Sewing Machines
Need to know how to properly thread , the problem is once we start to sew it moves a little then stops thread tangles on bobbin and breaks from top. we try different ways of threading
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
Mar 08, 2011 | Euro-Pro 473
Dont know if that its a q or not and cant figure out how to thread the bobbin
Make sure the thread is coming off the bobbin counter-clockwise, hold the end of the thread in your left hand, drop the bobbin into the case, and pull the thread into the slot at the front of the bobbin case by pulling it up and around the bobbin case to the left until you hear a click. That means the thread is in the bobbin tension. Then hold the needle thread in your left hand but don't pull on it; drop the needle into the machine and bring it back up by hand with the balance wheel, and as it comes back up, gently pull on the needle thread. That brings the bobbin thread up through the throat plate in a loop so you can pull it on out, and you're ready to go.
Feb 22, 2011 | Elna Quilter's Dream 6003Q
I have two problems the first is that as i sew sometimes the fabric on the back side gets stuck and there are many pieces of thread coming up from the bobbin and get stuck the second question is everytime...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Necchi 6011
Multiple threads are coming out of the bottom from the bobbin and stopping the needle.
Feb 21, 2011 | Husqvarna Husky 165
Bobbin thread tension issues
There might be a piece of thread or lint caught in the bobbin tension preventing it from functioning correctly.
Feb 24, 2010 | Janome L-344 Mechanical Sewing Machine
When threading Singer 57817 sewing machine, it won't pick up the
take out the bobbin, pull some thread from it. is it coming smooth without effort?
if yes, keep some thread outside and put back the bobbin and try again.
if thread is not coming out smooth, then check if something is stuck in the bobbin.
May 30, 2009 | Singer 57817 Computerized Sewing Machine
Singer 3116 Simple Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
