I think my stud finder has a weak battery, the beeping sound is weak. I like to change the batteries, but not able to find screws to open it, I am reluctant to pry it open.
I retired from fixing battery powered cleaning equipment a few years ago. The problem with wireless is that the batteries don't hold up. They will work fine for a few weeks- then they start to run out of juice after only a few min. On most rechargeables if you don't run them down completely, they only charge to the point you last put it on the charger (It's called battery memory). I personally think the rechargeables are a waist of money, and, when the batteries start to go- are frustrating. Just get an upright, with a side hose. I've got two at home that are over 20 years old. I only had to change the beater bar brush and belt twice in that time. No more than $150 bucks should be your price point for a vacuum used at your own home.
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Possible that the charging current is insufficient- maybe due to poor charging circuit, weak voltage .
Also it can be due to weak battery in the unit that does not take in charge . In such cases you need to change the battery.
I am afraid you are having the problem of old or weak batteries. Old batteries at times tend to show such problems and do not show charge while charging properly. For this purpose, you can use a reliable Nicad Battery Repair Guide through which you can recharge the batteries without any problem and make them work like the new ones within no time, without anyone's help and you can do this all by sitting at home! I tried it and now I never buy new nicad batteries (http://www.nicadbatteryrepair.com/).
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
sounds like you have two different issues here. (Possibly one common)
Clean out the cliff sensors. Under the bumper. blow it out clean. This might stop the reverse circling. The battery is either bad, or the charging circuit is bad. if battery is know good then the problem is the main board needs to be replaced. a bad battery will kill a main boards charging circuit by over working it with shorted batteries
