Question about Ovens
Need a function control dial
Dial unusable. how do I replace?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
You can buy a universal simmerstat or temp controller from Lawrence and hanson outlet (they may ask for rec no)
Posted on Nov 22, 2013
Temperature setting
try cleaning if that does not work you need to go for replacement .......
no other way........
regarding skills you should be very careful and taking all precautionary steps before cleaning.......
Oct 23, 2008 | Neff B1691 Single circotherm super...
I've moved into a new house and been presented with an oven like this.... Is there anyway to get replacement dials so I know which function I'm using?! Tecnik TKC201/2
Home Depot sells a number of different universal knobs and probably stock the ones you need. If not, you can Google your name brand and model number to find appliance parts specifically for your oven.
Aug 20, 2014 | Ovens
Help - Knob positions on New World Debut single oven
Don't know how long ago you posted this but I have the same issues! The left hand dial deals with function and the fan oven setting is 2nd one. The grill setting is the furthest one round...I think. The right hand dial is temperature. 180 is at about half past. 200 is at about 40 mins past if you get my drift. All this I have kind of figured out through trial and error... Now I've just got to figure out how to change the light bulbs....
Aug 22, 2012 | Ovens
STOVE WORKS BUT OVEN WILL NOT HEAT UP - GAS OVEN
There are 2 high likelihoods as to what your problem may be. When you turn your oven on, does the ignitor begin to glow within 15 to 30 seconds? If it doesn't, there is no power going to the ignitor and the control mechanism is going to need to be replaced. If you have a manual dial thermostat control, you can order this on-line at parstdirect.com. If you control is electronic, you will be required to have an appliance technician come out in order to send the old controller in to be rebuilt.
If your ignitor is glowing when you turn on your oven, but it has a very dull orange glow, you have a bad ignitor and it needs to be replaced. This is the most common problem with older gas ovens. The ignitors just burn out after time and do not draw the amperage needed to open the safety valve.
Replacing the ignitor is a fairly easy procedure. Replacing a dial thermostat control can be a little rough due to rerouting the thermocoupler back through the oven body. Unfortunately, the electronic style oven controls can only be sent in for rebuilding and the company that you use will need to be able to handle "Retforrepr Rebuilds".
May 01, 2011 | Magic Chef 9122 Gas Single Oven
I have a Frigidaire electric oven and flat cooktop that went out. Neither the oven nor the cook top elements heat up. If I turn the element dial slightly, the digital clock lights up (flashes), but...
With the symptoms that you are describing here ...the problem is in the control board... you still have power, but nothing is being told to turn on...the control board controls all of those functions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | Frigidaire Ovens
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Aeg oven
cant see controls on pic so this is guidance turn function dial to "oven" you may be able on this dial to select fan or convential oven. turn stat up to required temp. it is so easy that i just wonder if you haqve another problem. the usual is the clock set to "auto" in error. drag you handbook out and set the clock making sure you get in on manual. easiest way is to switch off at the wall and start from scratch. get back to me if this does'nt help
Apr 19, 2007 | AEG U7101-4 Electric Double Oven
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
