Question about Locks & Locksmithing
Speed release gun lock - Locks & Locksmithing
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Jul 16, 2014 | Porter Cable FR350A Factory Reconditioned...
Staple gun seems locked...brand brand new
look for a small button on the side that locks the handle down for safety and transport. It will be a slide button so push the handle down to release it and slide it back
Aug 03, 2013 | Arrow Tools & Hardware - Others
How do i get the lock out arm mechanism to disengage so i can use the gun
Trigger lock out is engaged when there are no nails in the gun. Load nails as usual to release. There is a pin just behind and under the door latch. Sometimes this pin will move up into the release catch when the pin oring is missing causing the door not to close properly effecting the lock out. Good luck
Sep 24, 2011 | Stanley Bostitch Rn461 Gun Coil Roofing...
How do I load staples into my JT21 staple gun?
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
How do you put staples in
There is a thumb release lever that keeps the slide bar locked down. Take your thumb and push up ******* this plastic release and it should open so that you can add staples.
Aug 27, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
Miller 350p welder gives a "help 3" code.
Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
To fix:
Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
Nov 17, 2010 | Miller Welding Tools
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Can a radar still display your locked speed if the unit is turned off. An officer gave me a ticket..  I was driving and saw the patrol car, my radar detector came on when he turned his on then he turned...
Yes. On many radar gun models the officer can lock your speed and turn the radar gun off, yet the radar gun will still display the locked speed. Officers are not required to show you the locked speed.
Apr 14, 2009 | STi-R Radar Detector
Locks & Locksmithing Logo
111 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
