Question about Goodman CLJ30AR32 Air Conditioner
Can a bad transformer send more than 24 volts to thrmostat
    Top Expert:
  • Goodman Master
  • 12,962 Answers
No. A transformer will only change the voltage upwards or downwards. If a transformer winding shorts out then the voltages would be lowered if unit even worked at all. Generally a shorted winding will cause the unit to overheat and just burn out completely; or the protective fuse will pop.
Defective electronics on power supply could account for incorrect voltage if the built in voltage regulators are not working properly.
Posted on Nov 23, 2013
I have a programmable White Rodgers thermostat. I noticed that the room was getting warm and when I checked the thermostat the display was blank. there are no batteries. I believe it runs on 24 volt...
Hello, the thermostat reveives 24 volts from the transformer located in tne furnace via the R terminal. If there is no display on the thermostat either you are not getting power from the transformer, the thermostat itself is bad. If you have a multimeter check for 24 volts at the r and c terminals on the integrated control boatd on the furnace with the door switched taped down, if no 24 volts then the transformer is bad. If you have 24 volts then most likely your thermostat is bad. Also, if there is. 5 amp fuse on the control board check it out, sometimes they go out if there is a short in the thermostat wiring.
Jun 12, 2011 | Heating & Cooling
No water flow into the filter
Hello. the first thing you need to determine is if the solenoid is getting 24 volts when the furnace turns on, you should be getting 24 volts at the solenoid valve. If not you need to start at the transformer and see if you are getting 24 volts there, if not then most likely the transformer is bad and must be replaced, if you are getting 24 volts at the transformer then check the wiring and make sure it;s tight. also check the humidistat and sail switch/ current sensing relay to make sure they are working properly. If you are getting 24 volts at the solenoid valve and is not allowing water thru than it must be replaced.
Feb 22, 2011 | General Filters 1099-LH Humidifier
It does not appear that my Carrier Infinity 96 is supplying the 24Vs required to my humidifier. Is there a swich on the control board that needs to be on or off to enable the humidifier power?
Hello, the control board supplies 120 volts to a transformer and then the transformer steps it down to 24 volts. check to see if you are getting 24 volts at the transformer if not then turn off the furnace and check the Resistance of the transformer, you should read resistance if not the transformer is bad and must be replaced. If you are not getting 24 volts and the transformer checks out good then a problem could be the wires going from the board to the transformer or portion of the control board is bad.
Feb 18, 2011 | Heating & Cooling
Water to selanoid ok wont come out other side it is a new selanoid
Jan 29, 2011 | Aprilaire 700 Humidifier
Water is not getting to the humidifier. Unit does not appear to be turning on when furnace starts
Check to see if you are getting 24 volts at the solenoid valve, if you are then the solenoid valve is bad and needs to be replaced. If you are not getting 24 volts at the solenoid valve then check to see if 24 volts is present at the transformer, if it is then check the wiring to make sure it's tight, humidistat, and current sensing relay/ sail switch. If you are not getting 24 volts at the transformer then turn off power to transformer and set your meter to continuity and check the secondary sie of the transformer, you should get resistance if not the transformer is bad and must be replaced.
Jan 21, 2011 | Aprilaire 600 Humidifier
Unit is less than a year old and the water does not seem to be entering the unit. the valve is all the way on and nothing is dripping out of the condensation line. Any ideas?
Check to see if your solenoid valve is receiving 24 volts by using a multimeter and putting each meter lead to each of the incoming wires to the solenoid valve, if you are getting 24 volts and the valve wont open replace the solenoid valve. If you are not getting 24 volts then Start at the transformer and see if you are getting 24 volts there, if you are then the problem is either loose wiring or the humidistat or sailswitch/current sensing relay is bad. If you are not getting 24 volts at the transformer then turn off power to the transformer and set your meter to read continuity, then take your meter and check the secondary side of the transformer for continuity, if none is read then replace the transformer.
Jan 19, 2011 | Aprilaire 600 Humidifier
I tring to change thermosat I can not remeber what color go where
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
Goodman CLJ30AR32 Air Conditioner Logo
192 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
