Question about Ricoh Aficio CL3500N Laser Printer
Ricoh sc 100-error sc541,heater not on - Ricoh Aficio CL3500N Laser Printer
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Cogz
  • 1326 Answers
SOURCE: about ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Posted on Apr 23, 2008
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
  • 1294 Answers
SOURCE: ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Posted on Dec 28, 2009
Service call sc541
change the fusing thermister
thanks
Nov 26, 2015 | Ricoh Aficio SP 3510SF
Sc 541 in sp 100
THIS QUIESTION NOT CORRECT , SC 541 ERROR IS SCANNER ERROR PLAESE CHEQUE THE SCANNER CABLE
Apr 28, 2015 | Office Equipment & Supplies
I have ricoh aficio mp1600 & this machine is error occoured Sc:542 how to solve this problem?
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Dec 03, 2010 | Ricoh Aficio MP1600SPF Copier
My aficio 1515 have a code SC541
sc 541 is a fusr error. please email me on ronils_singh@yahoo.com.au so i can email you a procedure to reset the code.
Sep 28, 2010 | Ricoh Aficio 2015 Copier
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Hi I have an Ricoh aficio CL7300 printer and it is displayin error message SC541 what does this mean and how do i Fix it
sc 541=Heating roller thermistor error (Fusing unit).
The thermistors could be dirty or damaged.
The fusing unit can be removed and inspected(without removing any screws)(Left door)(lower handle).
If you see any damage you might have to replace the unit(or only the part if u r lucky).
Feb 10, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
About ricoh copier problem
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio CL3500N Laser Printer Logo
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
