Question about RCA RS2625 CD Shelf System
Now audio output
Everything seems to be working except there is not sound. Any suggestions? Where do I get a schematic?
  • 661 Answers
You can get a service manual for about $5.50 from here, http://www.asm-service-manual.com/List/RCA%20List%20ASM.htm
Posted on Oct 09, 2007
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
RCA model# L46WD22YX11, TV works, Sound bar on screen moves but no sound. Any suggestions.
Check the speaker/s first. If found OK, check and replace the audio output IC. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 18, 2015 | RCA Televison & Video
Receiver wont play sound
Be sure to check all connections on the rear. Are both channels bad? Also if it has preamp output or rec out, u can check to see if those work with a external amp of some kind. Good luck. Let me know if you need more suggestions.
Mar 02, 2018 | B&K CT310 3 Channels Receiver
Subs not responding to Sony CDX-GT500
you cna switch the working rca's to the sub out put to check for sound if u get sound it means your rca's are bad but if no sound then your other outputs in your radio may be deffective
Jun 12, 2010 | Sony CDX-GT500 CD Player
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
321System No sound just humming with TV connected to Video1 or 2
Hi...
Get new audio cables . It seems there's a broken Ground (shield ) wire somewhere in the cable. NO ground means HUM usually
Dec 30, 2008 | Bose (321GS) System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Red light
It sounds like the output transistors have failed. Disconnect everything from the amp except for the B+, ground and remote and turn the amp on. If it goes into protect, the amp is in need of repair. If you want to repair it yourself, email power acoustic for the schematic.
Oct 02, 2007 | Power Acoustik LT-980/2 Car Audio...
RCA RS2625 CD Shelf System Logo
105 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
