Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Setscan failed (0xc0010011) - Zebra Symbol Technologies MC909X-G Series Barcode Scanner
My 2010 journey is over heating what can I do to stop it
Figure out why and correct this issue. There are numerous things that can cause overheating and many are beyond the average do it yourself repair. Some possible causes are: failed thermostat, failed water pump, broken water pump belt, low coolant level, failed cooling fan, failed electrical cooling system, failed heater core, leaking hose, air pocket in cooling system, failed radiator cap, failed radiator, cracked head, cracked block, failed headgasket etc. Beware it only takes one time overheating to damage the cylinder head or headgasket. Get that checked.
Oct 28, 2016 | 2010 Dodge Journey
Can't connect wifi
Some things to check
  1. Make sure WiFi is powered on
    1. Go to Windows CE desktop
    2. Click on wi-fi power icon
    3. Click 'Turn on'
  2. On Windows CE Task bar
    1. Double-click on WiFi (First from left)
    2. Click on 'Wireless Information' tab.
    3. Select your network from network list
    4. Double-click on i
    5. Enter your network credentials
    6. Press OK
    7. Right-click on your network name
    8. Press connect.
Dec 18, 2014 | Motorola Mc2180 Data Collection Terminal...
Failed to log you into Miniclip, please contact support@miniclip.com
Nov 15, 2012 | Video Game Consoles & Games
Llomy id is blocked help me to unlock
Checking virtual IP servers...
[VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED]
 ***  'COMPONENT_TYPE_WININET' value: '12029' ***
[VIP Raw] Resolving host name vcs2.msg.yahoo.com... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED]
[VIP Raw] Resolving host name 98.136.48.100... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.100... [FAILED]
[VIP Raw] Resolving host name 98.136.48.110... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.110... [FAILED]
[VIP Raw] Resolving host name 67.195.187.228... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.187.228... [FAILED]
[VIP Raw] Resolving host name 67.195.187.229... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.187.229... [FAILED]
[VIP Raw] FAILED
 ***  'COMPONENT_TYPE_YCP' YCPError: 'YMSG.ColoSelectionFailed' ***
Checking HTTP virtual IP servers...
[VIP Http] Resolving host name httpvcs1.msg.yahoo.com... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.136.48.229... [FAILED]
[VIP Http] Resolving host name httpvcs2.msg.yahoo.com... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.139.61.47... [FAILED]
[VIP Http] Resolving host name 216.155.194.137... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 216.155.194.137... [FAILED]
[VIP Http] Resolving host name 98.136.112.142... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.136.112.142... [FAILED]
[VIP Http] FAILED
Apr 19, 2011 | Yahoo Messenger
How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Oct 19, 2009 | Esker VSI-FAX 4.x (25301) for Unix
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Horn and power seats quit working. maxi-fuse extremely hot. pulled it out and re-inserted after it cooled down. fixed the problem temporarily (a day or so). swapped that maxi-fuse with the one above it...
which maxi fuse gets hot ? # fuse , plus amps The power seats uses a 30 amp circuit breaker ,not a fuse . The horn gets power from the same circuit breaker . . Sounds like something is drawing to much current. Do you know how to use a amp meter to test current flow . Disconnect componets till draw goes away ? How to use a wiring diagram to pin point areas in a circuit to test ?
Is there corrosion on the pins where the seat circuit breaker plugs into ? Reach under your seats an see if one of the seat motors is hot .
DeVille
The left and the right power seat system consist of the following components:
• The seat switches
• The seat relay modules
• The 4 reversible motors:
- The front vertical motor
- The rear vertical motor
- The horizontal motor
- The recline motor
These 4 motors operate independently of each other.
When the entire seat switch is pushed to the FORWARD position, the forward input of the of the seat relay is grounded.
The seat relay module supplies battery positive voltage (B+) with a ground to the horizontal motor, in response to this input. In order to drive the seat forward, the motor runs until the switch is released.
The BACK position works similar to the FORWARD position with the exception that the voltage polarity supplied by the seat relay module is reversed causing the motor to run in the opposite direction. This action drives the seat backward.
These recline switches operate similar but independently:
The seat relay module could be bad , If you don't know how to do automotive electrical circuit testing it mite be a good idea for you to take your vehicle to a qualified repair shop.
Could have diagnostic trouble codes stored as well .
DTC B0846 +5 Volt Reference Out of Range
DTC B0856 Battery 2 Out of Range
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1982 Source/Battery Voltage High
DTC B1983 Source/Battery Voltage Low
DTC B2101 Recline Aft Switch Failed (Eldorado)
DTC B2101 Recline Aft Switch Failed (DeVille)
DTC B2102 Recline Forward Switch Failed (Eldorado)
DTC B2102 Recline Forward Switch Failed (DeVille)
DTC B2103 Rear Vertical Down Switch Failed (Eldorado)
DTC B2103 Rear Vertical Down Switch Failed (DeVille)
DTC B2104 Rear Vertical Up Switch Failed (Eldorado)
DTC B2104 Rear Vertical Up Switch Failed (DeVille)
DTC B2105 Horizontal Aft Switch Failed (Eldorado)
DTC B2105 Horizontal Aft Switch Failed (DeVille)
DTC B2106 Horizontal Forward Switch Failed (Eldorado)
DTC B2106 Horizontal Forward Switch Failed (DeVille)
DTC B2107 Front Vertical Down Switch Failed (Eldorado)
DTC B2107 Front Vertical Down Switch Failed (DeVille)
DTC B2108 Front Vertical Up Switch Failed (Eldorado)
DTC B2108 Front Vertical Up Switch Failed (DeVille)
DTC B2109 Lumbar Aft Switch Failed
DTC B2110 Lumbar Forward Switch Failed
DTC B2111 Lumbar Down Switch Failed
DTC B2112 Lumbar Up Switch Failed
DTC B2115 Recline Sensor Failed
DTC B2116 Rear Vertical Sensor Failed
DTC B2117 Horizontal Sensor Failed
DTC B2118 Front Vertical Sensor Failed
DTC B2119 Lumbar Forward/Aft Sensor Failed
DTC B2120 Lumbar Up/Down Sensor Failed
DTC 2130 Seat Motor Failure
Aug 10, 2017 | 1997 Cadillac DeVille
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
504 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
