Question about Epson Office Equipment & Supplies
Epson 9600 maintenance error 0080 - Epson Office Equipment & Supplies
Inky
  • 691 Answers
SOURCE: Hey All
This error relates to the encoder strip for the carriage motor. The encoder strip is like a piece of graph paper and the head has an eye that reads how many lines it passes. This is so the machine know exactly where the head is at any point.
The error means that the machine is not correctly reading the encoder impulses. This could be because the encoder has broken, the eye has gone blind or a circuit board or cable has become faulty. It could be that if you have done maintenance that one of the connectors has been replaced with incorrect polarity.
Check the basics first:
  • Is the encoder attached and correctly routed through the optical sensor
  • Is the encoder strip clean - if there is a splodge on it, this will result in error
  • If you have done maintenance, check all the connections you made are good
If you need further help with this, there a good section in the service manual that gives a sequence of areas to test to pin down the fault. Get a manual from http://www.TheServiceManualShop.com
Posted on Oct 13, 2007
  • 3278 Answers
SOURCE: maintenance required 0040 code
Hello.
Your error code means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
You can continue to print, but soon you will experience leaking ink, damaged hardware and poor prints.
Hope this helps.
Posted on Nov 14, 2009
Ezrahite
  • 2632 Answers
SOURCE: Epson Pro Stylus 9600 is
Welcome to Fixya.
Your error code req 0040 means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
Here is the solution for your prob. Turn Off your printer then press the Left, Down arrow and Enter simultaneously then power On the printer. inside initialize the sponge and cleaner then turn Off and On your printer.
You have to replace your pump cap assembly if it is already poor in cleaning otherwise your printhead will suffer.
Thanks for using Fixya.
Posted on Feb 15, 2011
  • 158 Answers
SOURCE: we have an EPSON STYLUS
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Posted on Mar 01, 2011
caroldon
  • 17130 Answers
SOURCE: maintenance req 0040 on my
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Posted on Aug 09, 2011
What is the solution of error 0080?
0008 - RTC error (Real Time Clock) (Check the Battery and reset the Date and Time)
Jul 26, 2014 | Epson Office Equipment & Supplies
Error 0D050000
Check the cartridges. either any cartridge is dry or empty
Dec 30, 2013 | Epson Stylus Pro 9600 InkJet Printer
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Maintenance required 0040 code
Hello.
Hope this helps.
Nov 14, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
