Question about Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC)
Colors on card do not print well
When printing card, part of the card do not print well. the color differ at one end from the other
3 Suggested Answers
  • 4 Answers
SOURCE: the card comes out all in black color why?
Before we start first things first, you DO have the color ribbon installed correct? If so, go to control panel, click Printers and faxes, right click the evolis printer icon, scroll down to properties, open it up, click the graphic tab, then select 6 panels ribbon (YMCKDK) that should do it since I had the same problem.
Posted on Jun 02, 2010
  • 54 Answers
SOURCE: ribbon cut when printing a standard test card
Check for ribbon setting in driver. Run self adjustment process
Posted on Apr 27, 2011
I have a Cannon Powershot SX120 and the color is off. What can I do? I have tried different things in the manual but I end up frustrated.
You didn't provide enough information so I'll try this.
If the color is off on your prints or on your computer screen when you try to view the photos from the card, you might check your computer's color setting to ensure that you have it set correctly, IE. ADOBE RGB, CMYK, etc. This is also the same potential fix for printing photos.
Sep 24, 2015 | Cannon Cameras
Tip
Using a color enlarger to print both color and black and white photos
Some enlargers have dials on the front that are labeled yellow, cyan and magenta. These enlargers are made to print both black and white and color photos. To print in colors you use the dials to perfect the colors of your print. Let say that you took a picture and the colors look to be a bit off. In the light you would hold up a color filter to the image and decide which filter makes the color look closest to what you want the final image to look like. Then taking the information on the card you go back into the dark room and adjust the dials on the enlarger according to the card that was used. If you were looking through a green filter then you would lower the number on the magenta dial.
Printing in black and white on an enlarger with these dials is a little different. Since there are no colors in the black and white paper these dials have a different function. They are used to adjust the contrast of an image. If you turn the light on in the enlarger without paper under it and turn the dials you will notice that the magenta will make the light darker. When you print with the yellow and cyan dials at 0 and magenta at around 10-20 this will add contrast the image. You can always develop all your negatives without touching any of these dials, but if you can master them then your images will have a little less flat than those with little to no contrast.
on Oct 01, 2013 | Photography
Printing from coreldraw 5 to zebra p330i
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
Aug 08, 2012 | Zebra P330i Thermal Card Printer
Have an HP laserjet cp2025 - the printing comes out faded although the test page prints fine. What's happening?
sounds like you either have econo-mode set which would be in the printer driver or your screen colors do not match your printer colors. Your easiest test is to open mspaint and create a block of just one basic color like yellow. If it prints fine then the programs you are trying to use are not sending the right color instructions to the printer. Never expect a low end color such as this to match your screen out of the box, it will not happen. You either have to accept the color difference or spend the money to buy a color matching device which creates custom drivers for your printer and screen so they look the same.
Mar 21, 2011 | HP Office Equipment & Supplies
Dark display on hp 4600 color laserjet
This could be a faulty Formatter board. Can you swap it with a good one?
Mar 02, 2010 | HP LaserJet 4600dn Color Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Brandnew printer nwill not print colour
Hi super_um
Assuming you have already checked the color cartridge and ink
Type something in color and try to print
Do not use the Printer Icon, instead go through the menu bar and select print
On the the print dialog screen, click on the properties,
Under color: options: you will have options like the following:
Print in color
Print in B&W
Print in grayscale
(Depending on the Brand of the printer, the wording may be different)
Make sure you select "print in color" option and leave it like that always. On the other hand, if you select black, all the different colors will be printed in black or gray.
Hope this will work for you
Good luck
luciana44
Sep 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Every program prints the colors on my photos different than how they look on the screen. What setting will calibrate all to be the same? I have a Samsung 23in widescreen lcd monitor, and use Lightroom,...
That happens because the screen color resolution is better than the printer color resolution. You can set your color scheme down to 16 colors. Right click on the screen and select the appearance tab to change the color resolution
Aug 16, 2009 | Office Equipment & Supplies
Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC) Logo
12 people viewed this question
Top Evolis Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Fred Block
Fred Block
k24674
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
