Question about Bose QC15 Headphones
The sound cuts out if my headphones are bumped or if i tap the hole at the bottom
When sitting on the train and other trains passed by, the sound cut out. If something rubs along the bottom of them, the sound cuts out. If i tap them or the hole underneath, the sound cuts out. When the sound cuts out, it is only momentarily
5 Suggested Answers
bluemage77
  • 22 Answers
SOURCE: Bose in-ear headphones sounds cuts in and out
Well, here's a temporary fix until you guys can get new ones. Pull the plastic stopper about halfway up the phones. Then loop the bottom of the entire headphones through the circle that the plastic stoppers create. When you have a tiny loop, pull the upper stopper down and tighten it. People said that they needed to angle the cable in a certain way, right? Well, this fixed mine for now. Just keep it in that position until you can get a replacement or they come up with a permanent fix.
Posted on Jun 09, 2008
SOURCE: wire has been cut
My wire was cut, and I made it worse trying to fix it....with several failed attempts... was becoming despondent, but gave it one last try, and was successful. First, each little tiny wire has two internal wires, one green (ground) and one gold (hot). At first, the green one looked like some fiber or filler and I cut it, connected the gold wires and nothing happened. On further inspection, with magnifying loopes, I determined the green fiber was in fact green wire. There was also a lot of clear fiber, which is insulation? filler?... I don't know, but I cut it out, leaving only the wires. From the internet, I determined that the wires had a thin layer of plastic on them for insulation, which I burned off lightly with a lighter, connected the green together, soldered it, wrapped in electrical tape, then connected the gold together, soldered it, and taped again....and to my suprise it worked. I used twist ties, and epoxy to strenthen the area and was done, my headphones are working again.
Posted on May 16, 2009
  • 1138 Answers
SOURCE: headphone wire has been cut
Here is a link to how to do it:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/ I hope this helps.
Posted on Nov 26, 2009
Grubhead
  • 5362 Answers
SOURCE: I realized the wire in
You might want to take a look at my Tip on headphones. Just click my user name to find it.
Posted on Feb 12, 2011
My son got this train set couple years ago but open it now. Everything is working but it won't move. When he turn it forward or reverse it turn off. Is there anything I can do???
electric trains that sit for a few years require cleaning (yeah I know how'd it get dirty in the box ) but its not the same kind of dirt u/I see its a type of oxidation called corrosion , and it affects the metal parts of set , IE: tracks , wire connectors, engine power pick-ups on bottom of engine they ALL get this light powdery stuff on them this "stuff" will not pass power over to engine and it will not run , this powder can be easy removed with a light rub of 3M scotchbright pad , I don't recommend using steel wool , but I have in a pinch before and 4 sure don't use brillo as this has soap in it (worse than powder)
Feb 21, 2016 | Lionel The Polar Express Train Set
How to cuting a hole in a chain link frence pdf
I've never heard of cutting a hole in a chain link fence before. I'm considering installing one of these around my own yard to help keep my dog on my property. My family recently bought him and he still isn't that well trained. I think something like this would help immensely. Chain Mesh Fencing Melbourne Chainmesh Security Fencing
Jul 03, 2014 | Home Fencing
Harley head lights cut on and off
Most likely on the bulb itself if you haven't done any work previous to the problem
Apr 17, 2014 | 2006 Harley Davidson FXSTB Night Train
42LD520 sound shorts out
if it has a headphone jack it could cause this--the jack when inserted cuts off the speakers to engage a headphone--try inserting a jack when it does this and wiggle it a little--jack socket has leaf contacts that can be out of position
If tapping it could also be a bad solder connection somewhere.
Apr 08, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
I have an electric RYOBI weed eater and I need HELP...manual/instructions on how to access the spool so I can feed the line through the exit hole and use the thing! Thank you. Have two numbers: EL...
Unscrew thw bump nut to remove the spool. Take a length of about 6 foot of line, kink it in the middle and pass this through the hole in the spool. Wind the two lengths of line around the spool in their own divisions and in the same direction. The direction of wind is embossed in the reel and the line should be wound tightly and held all the while. When you have about 6-8 inches left in your hand, bring the cover up to the spool and carefully pass the two ends of the line through the holes, push the cover all the way over while pulling on the two pieces of line and ensuring that the lines stay on their own side of the division on the spool. Fit and tighten the bump nut and trim the lines to just about the cut-off blade.
The lines should trail out of the holes in the direction of the machine's rotation. Try cut with the tip of the line as much as possible. Cutting nearer the drum flexes the line and will lead to early breaking of the lines. Run the motor at a constant speed and rather move the cutting head in and out of the weeds to affect a deeper cut
Jul 09, 2011 | Ryobi 15" Electric Factory Reconditioned...
Dont no how to string the head
Apr 29, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
I lost my job, and am in need of dog haircut instructions.
I had a dog with hair. I couldn't afford to take her to the groomers, so I bought an Oster Animal Hair clippers and just buzzed off the hair myself. They have little attachments to go on so they don't cut so short. If you mess up, the hair grows out. My kids used to laugh at some of the hair cuts. I had to train Buttons to hold her head very still when I cut around her eyes. That part scared me, but she did hold still. Some times I had to let her run around awhile and come back to the hair cut in 10 minutes. I also had to train her to lay on her back for the tummy & chest trim. She never did like the toenail trim though. I had to sit on her to get it done. Luckily she was only 13 lbs. I did her hair twice a year and sometimes 3 times. I used the scissors on her feet too. Check at Fleet Farm, Target, or Sally's Beauty Supply for cutting tools.
Mar 29, 2009 | Google Computers & Internet
Hello: Train won't move
CHECK FOR SWITCH ON BOTTOM OF TRAIN
Dec 07, 2008 | New Bright Toys
Need replacement track for train set
is there a way to make wooden tracks for this inflatable to sit . all you would have to do is measure the distance between the wheels and the cut the lumber and screw together. i would use 2 x 4 x 8 feet long . and cut the braces just the right lenght so the train would sit on the track. you could even paint the rails gray or silver and the braces black to off set the colors of the train it self .
Dec 01, 2008 | Animated Inflatable Christmas Train
Bose QC15 Headphones Logo
60 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
