Question about Furniture
Can't unlock drawers to remove - Furniture
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
How do you remove the fabric softener dispenser? No clip ring, does not lift up.
Pull out drawer unlock Despenser by pressing the release lever on left hand side of dispenser mine is a grey plastic stick out about 2inches press it down and pull drawer completely out. Dispenser pops out be care the grey stick (about 4inches) pops off and must be reinstalled in its proper slot. Drawer slide back naturally
Jul 07, 2015 | Maytag Washing Machines
How can I pry open an unlocked but Jammed file cabinet drawer?
The issue is probably a worn out drawer interlock - that is to prevent you from opening more than one drawer at a time so the unit will not tip over on you.
Remove one drawer and check the mechanism (worn out or bent).
JOAT
May 09, 2014 | Office Equipment & Supplies
Minolta di520 error code C0990
C990-C994 3rd drawer lift up and 3rd drawer elevator motor failure.Check the actuators and two motors .
Removal of the 3rd drawer:
1.Press the paper descent key and slide the 3rd drawe out to the front.If pressing the paper descent key does not allow you to slide out the 3rd drawer,insert a screwdriver or similar object trough the hole in the rear cover and unlock the drawer.
2.Remove 4 screws on the slide rails and pull the 3rd drawer out to the front.
3.Unplug 1 connector,loosen 2 thumbscrews to remove the connector board assy and remove the 3rd drawer.
4.Remove 4 screws,unplug one connector and remove the cover.
5.Remove two screws and the drive bottom cover.
6.Check the gears.
Aug 13, 2012 | Office Equipment & Supplies
The place where my fabric softener seems to be stopped up. When my clothes are finished washing, this spot is filled with water. How can I get the drawer out to check out this problem? I think the drain is...
Pull the drawer all the way out till it stops. At the rear of the drawer, you will find a button to push down and it will unlock the drawer to remove out completely. Good luck.
Jun 20, 2011 | LG WM1814CW Front Load Washer
How do I replace the cabin air filter on my 2005 Toyota Matrix?
For 2005 Toyota Corolla (and Matrix), the location of the cabin air filter is inside of the drawer (passenger side). Open the drawer, you will see a screw on the RIGHT hand side. Unscrew it with a cross shape screw driver. Unlock the drawer from the screw holder. And take the drawer out of the cabin. After the removal, you will be able to see the location of the cabin air filter. There is a lock at each side of the filter cover. For each side, use two fingers to pinch the lock and pull out the cover. You will see the old filter after removing the cover. Pull it out, and insert your new filter.
Put the cover back. Make sure the two locks are firmly locked. Put the drawer back. To make this work easier, you may lock the bottom of the drawer first, as there are TWO locks on each side of the bottom drawer. Close the drawer to see if the position is right. Place the screw back, that's all
May 23, 2011 | Toyota Matrix Cars & Trucks
I have an Everex PC Tower. My cd/dvd/drawer is jammed shut. How can I get it open? Thanks, Craig Knapp Monroeville, Ala
Turn the computer off.
Take a Norwegian paper-clip.
Straighten one end.
Push that end into the small hole in the face-plate of the CD, until you feel resistance.
Push another 0.25 inch (6 mm), and the drawer should "unlock".
Gently pull the drawer open, and remove any disk(s).
Oct 22, 2010 | Everex DESKTOP PC EVEREX | GPC TC2502 RTL
ASKO 6021 washing machine, drawer locked
Reach under the drawer, right side and move the lock mechanism to he left. The drawer will unlock.
Mar 22, 2009 | Asko W6021 Front Load Washer
Phaser 860 maintenance tray A stuck
1. The Maintenance Drawer will not come out. - Often times this can be overcome by waiting 2 minutes for the ?Hot Ink? timer to expire, then remove the Maintenance Drawer. 2. If the printers Maintenance Drawer is locked in place and can not be removed and there are no cleaning functions currently taking place then the Maintenance Drawer can be unlocked by removing the right side cover and move the Cap/Wipe/Purge belts evenly down to the home position. This will raise the sensor flag from I/O Left and disengage the locking pin that is preventing the Maintenance Drawer from being removed. 3. If either Maintenance Drawer Guides (Blue Plastic Rail guides) have been replaced or removed and reinstalled and this is preventing the proper insertion of the Maintenance Drawer then check on the outside of the chassis frame that both rear locking tabs for the rail guides are protruding through the printers frame and are properly seated and notched into place. ? If they are not properly installed and seated then remove the rail guides and reinstall and then test for proper insertion and removal of the printers Maintenance Drawer. 4. Obstructions or spilled ink (wax) may be covering the Drum Maintenance rail guides and preventing the proper insertion or removal of the Maintenance Drawer. ? Check the printers Drum Maintenance Rail guides for any paper scraps or spilled ink or leaking ink from the Printhead. Make sure that there is no spilled ink under the Maintenance drawer waste tray and that it is seated properly. TROUBLESHOOTING TIPS AND HINTS: In order to provide more clearance when removing the printers Drum Maintenance rail guides, use the X-axis gear to move the Printhead away from the drawer guide that you are removing/installing. Also raise the Cap/Wipe/Purge assembly to reduce interference. When a drawer rail guide is mounted, double check its rear locking tabs where they go through the chassis side frame. Both blue tabs should be visible on the outside of the frame of the printer.
Apr 28, 2008 | Office Equipment & Supplies
Door won't unlock
pull out the dispenser drawer push down on the tab remove the drawer and there is a cord you can pull to unlock the door pull on the door same time you pull the cord
Feb 18, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Furniture Logo
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
