Question about Cooper Wiring Devices Electrical Supplies
I have two "cooper wiring devices" "390-6107XX-EG1D" occupancy sensors in a circuit at the top and bottom of a stairway.which are generating huge amounts of noise in the AM radio band. All the time
Two "cooper wiring devices" "390-6107XX-EG1D" occupancy sensors in a circuit at the top and bottom of a stairway.which are generating huge amounts of noise in the AM radio band. All the time its "ON" (has turned on the lights) the AM radio generates nothing but noise. (I have tested by removing all other items from the circuit. Even when they are the only thing in the circuit, when they are "on' they still makes noise. Both are grounded to metal conduit. Is there anyway to stop the static?
4 Suggested Answers
  • 1214 Answers
SOURCE: Installing cooper 30A 250V female receptacle.
Correct, assuming red and black are connected to the breakers in the breaker panel, and white is connected to the neutral/ground buss bar in the breaker panel.
Posted on Dec 17, 2009
Testimonial: "I guess they didn't bother to check the instructions. I Just went ahead and wired it the way I thought it should be wired and everything worked fine"
SOURCE: i just bought a switch
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Posted on Oct 03, 2010
mikadot
  • 2113 Answers
SOURCE: radio static from cooper wiring devices occupancy sensor
Use only incandescent light bulbs on those and test again.
Posted on Nov 21, 2013
Testimonial: "Circuit has only got incandescent bulbs, further noise happens even when there are no bulbs in the circuit. i tested it with and without."
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit.
I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
Apr 16, 2016 | Leviton Electrical Supplies
Cooper wiring devices 390-6107xx-eg1d wiring diagram
This is the Cooper product #6107; Standard Series Occupancy Sensor, 3-Way, 500W/400W, Incandescent, Halogen, Fluorescent Rapid Start Ballast.
Do NOT use to control light fixtures with CFL or LED lamps!
Connect this switch by using the diagram for the #6107 Single-Pole or 3-Way (match your existing switch) linked below.
https://objects.eanixter.com/PD365967.PDF
Dec 01, 2013 | Cooper Wiring Devices Electrical Supplies
Radio static from cooper wiring devices occupancy sensor
Nov 21, 2013 | Cooper Wiring Devices Occupancy Switch...
Remove the two sensors. If they are connected to your lighting on the same circuit you may need to replace then with '3-Way Switches'.
Also see this warning: http://www.saferproducts.gov/ViewIncident/1232148
Nov 21, 2013 | Cooper Wiring Devices Electrical Supplies
I want to replance a standard wall switch (2 wires: white & black) with a PIR Occupancy Sensor switch
Copy following link for simple walk-thru how to wire occupancy switch
http://waterheatertimer.org/How-to-wire-occupancy-switch.html
This device is made to replace single-pole switch.
Power to fan: note the horsepower range for device: for example if occupancy switch is rated 1/4 Hp, then it will work for ordinary bath fan. If device is rated for 1/3-1/2 Hp then it is rated for whole-house fan.
Each fan motor will have rating plate showing Hp. Check rating labels for each device.
http://waterheatertimer.org/Color-codewire.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 08, 2013 | Hardware & Accessories
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
Is their a way to adjust the delay time on a 390-6107xx-eg1d motion sensor light? If I stand still it cuts out in 3 seconds
There is a switch on the front that allows for different times before shutdown. Also there is a smaller dial beneath the panel that lets you adjust the sensitivity. Try adjusting it to be more sensitive ( + ) so that you are seen and then the timer should kick in.
Feb 28, 2011 | Cooper Wiring Devices Motion Sensing...
I have a stairs with a switch and a bulb on each floor and i need to replace them with a wall pir sensor on each floor i need the wiring diagram
I answer questions for free.
I know electrical wiring.
I am unsure about a few things in your question.
Are you wanting to know how to wire a product you purchased?
Are looking for a wiring diagram to see if you can do what your want?
1) Is your circuit a 3-way circuit with 2 switches controlling both lights?
2) Or are there 2 different circuits where each switch controls one light?
Here is a Leviton manual with wiring for occupancy sensors:
http://waterheatertimer.org/pdf/Leviton-IPP0R-1LW.pdf
If you want sensors to replace 3-way switches, you need a control sensor and a remote sensor.
Click link below to see this image clearly
http://waterheatertimer.org/images/3-way-sensor-600.jpg
Add a comment and I will get back to you with specific details about wiring.
Oct 31, 2010 | Cooper Wiring Devices Motion Sensing...
2006 mini cooper, passenger seat sensor detector, how to r & R. thanks
Hey,
take a look at www.airbagmodul.com
They're working in Airbag-Simulators and Occupancy Sensor-Simulators.
Regards
Gerrit
Feb 10, 2010 | 2006 Mini Cooper
Mini cooper airbag light stays on
Hey,
Regards
Gerrit
Mar 11, 2009 | 2005 Mini Cooper
Open Questions:
Electrical Supplies Logo
121 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
Steve
Dennis Boxerman
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
