Question about LG DLE2514 Electric Dryer
Black Marks on Clothes Coming out of the Dryer
I saw a post from drsdrs on July 6, 2007 that described my problem to a tee. "We find small black marks on the laundry at the completion of the drying cycle. The black marks can be removed with soap and water." However the answer to drdrs did not help me as my dryer has done this since the first time we used it brand new and it is only a year old now. If the drum rollers are bad then they were bad when the machine was sold to me. Could there be another solution?
  • Anonymous Nov 28, 2007
    My LG dryer also leaves black marks on clothes. I have had it repaired two times (drum and rollers replaced), but the problem is back. Just spoke with customer service at LG and was told that an appliance has to be repaired three times w/o success before they will exchange it for a new one.
Follow-up the Nov 28 post: Just got my replacement dryer after many phone calls to LG. The installer told me that the black marks were from using dryer sheets. He said the ozone system in the dryer breaks down the chemicals in the dryer sheets. Doesn't explain why the problem seems to be fixed when roller and drum is replaced then returns after about 2-3 months.
Posted on Jan 10, 2008
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer leaving small black marks on light colored clothes
Disassemble and look for lint issues, your description could be caused by burnt lint coming off of the burner.
Apr 22, 2011 | Maytag Dryers
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Makes a noise like there is loose change in the dryer. Grey marks are coming off onto the clothes. checked. there is nothing inside the dryer or in the pockets of the clothes. Still happens- even with...
This sounds like a faulty drum bearing. The grey marks you are seeing are grease from the bearing. The loose change sound is from the remnants of the bearing rotating as the drum turns.
Mar 09, 2010 | Dryers
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Front loader leaving black marks
had the same problem. Tried changing the washing powder to no effect.
Jul 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Black oil or grease on clothes after washing
is you machine a top loader or front loader? if its a front loader the black marks could be from the boot. WIpe the boot with a good cleaner. and try not to over load machine. and if it a top loader your transmission is probably leaking oil back into clothes tub. You could have it rebuilt $$$ or better replace the machine.
May 22, 2008 | Washing Machines
Black marks on clothes
Your going to have to get service for this one. Chances are the rollers are gone and the black is coming from the rubber onto the felt and then transfering to your clothes.
Sgt 48
May 11, 2008 | LG DLE2514 Electric Dryer
LG DLE2514 Electric Dryer Logo
319 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
