Question about Maytag Neptune MDG6800 Gas Dryer
Code 99 on electric maytag neptune dryer? - Maytag Neptune MDG6800 Gas Dryer
Illeagle
  • 525 Answers
SOURCE: maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
SOURCE: Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Posted on Feb 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: Can the Maytag Neptune Gas dryer converted to electric?
A gas dryer is dedicated to the use of gas to supply its heating function. It works on 125 volts. No way can a gas dryer become an electric one. UNLESS!
you just want to hang out yer clothes under the sun and use the dryer as a way to fluuf up yer clothes OR you could place the dryer into a box and make a condenser dryer out of it. Like cool hand luke you will toss that dryer into a rigid metal box in direct sunlight so that it can be an unbearable 140 degree up in there. then grab yer clothes and toss em in there and close that tar paer lined tin box up my friend.Let the sun do its thang. I think i just invent the redneck dryer! we don't need no stinking gas. Green power to the people! LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 08, 2009
erickg
  • 116 Answers
SOURCE: how to hook up a cord to the maytag neptune dryer color codes
these are single phase so just copy red to red black to black white to white and green is ground
Posted on May 04, 2009
  • 351 Answers
SOURCE: Maytag Neptune Dryer smells like burning rubber or plastic...
could be the board, could be a motor, could be a belt but i would run it intill something just stops or try your best to take it apart and look through things and see if you can see an indication.
Posted on May 09, 2009
What does fault code 99 indicate?
What? 2days? Call the installer! or seller. Could be a gas supply safety problem!
Mar 24, 2012 | Maytag Neptune MDG6800 Gas Dryer
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I have a maytag neptune electric dryer with a t3 code how do I fix it.
Take another look at that code. There is known "T3" error code for this dryer.
Jan 22, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Dryer stops and Beeps with Error code E60
At MaybeNow online guides are always there to provide technical support to troubleshoot Maytag Neptune MDE6700A Electric Dryer Problems which is free of cost. You can also get Maytag Neptune MDE6700A Electric Dryer, Dryers Help from archived solutions related to repair, maintenance
Dec 21, 2010 | AEG T57800 Electric Dryer
How to hook up a cord to the maytag neptune dryer color codes
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
99 minutes
It sounds like you may need a new timer. Has water or anything gotten into the timer. This could be causing a short or faulty reading in it.
Dec 20, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag Neptune MDG6800 Gas Dryer Logo
82 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
