Question about Fujitsu ScanPartner fi-5120C Pass-Through Scanner
Asc code DS42037
When try to scan error report comes as below WHEN SCAN ERROR CODE SHOWS AS ASC CODE: DS42037 SENSE KEY 0 X 4 ASC 0 X 680 DDES: 0 X 74
4 Suggested Answers
NateOcean
  • 14 Answers
SOURCE: Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Posted on Apr 11, 2009
SOURCE: fujitsu 5900c E18 error
Need to replace exit sensor
Posted on Jan 13, 2010
TechSatya
  • 104 Answers
SOURCE: sense key=0x4,asc=0x48,ddes=0x88
Hello Adil,
Does your scanner display H0/H8 alarm?
Does the same symptom occur after turning OFF and ON the scanner?
Does any foreign object get inside the Control PCA? Check the control PCA.
Are the cables between Control PCA and the motor damaged? Or are the
connectors connected correctly? Check throughly.
If the issue is not resolved, then you may have to replace the Control PCA as the motor fuse is located in the control PCA unit. For replacement you are recommended to contact Fujitsu scanner expert.
Thanks,
ScanCare
Posted on May 23, 2012
Sense key=0x4,asc=0x48,ddes=0x88
Hello Adil,
Thanks,
ScanCare
Jan 22, 2012 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu fi-5750C flatbed will not scan. I keep getting an error "Irregular status is detected in the scanner. Anomaly in Flatbed motor operation. There are some codes: Sense Key = 0x4; ASC=0x580;...
Mine came with the same error message. If you look through the glass into the left front corner, you should see a spring loaded belt tensioner device. It merely hooks into the bottom plate against a spring to keep the belt tight. On my 5750C, the belt tensioner had slipped out of the base during shipping. The hardest part of inserting it back into the base was getting to it. Directions to do that are on this site at .../support/t484836-taking_apart_flatbed.
Sep 20, 2011 | Fujitsu fi-5750C Flatbed Scanner
They are getting a warning on the light bulb\r\nSense Key=0x4 ASC=0x680 DDES=0x7E
Hi Dana,
The error you are receiving is Flatbed Optical Alarm.This alarm occurs when the READ command for the first document is received, or when gain of the CCD amplifier is adjusted (sheet guide is read) during scanning.Probable causes are:
- The lamp, optical system or white sheet guide is dirty
- Defective lamp, heater, CCD, or inverter
- Connector disconnected
  1. Does the same symptom occur after turning OFF and ON the scanner? Check the scanner.
  2. Is the White sheet guide (glass) in the FB cover dirty? Remove the FB cover and clean the White sheet guide (glass).
  3. Is the Optical unit dirty?Are cables damaged?Are the connectors connected properly?Check all.
  4. Do the Lamps FB light up?Are cables damaged? Are the connectors connected properly? Check if the lamps light up during the Paper feeding test.If not, the error is caused by the defective Lamp FB or Inverter.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 16, 2011 | Fujitsu fi-5750C Flatbed Scanner
There is a symbol on the dash showing a circle with a traingle and and exclamation mark in the centre
This is the ASC indicator. It comes on when the system is turned off. To get the light out, turn the system back on by pushing the ASC(dsc) button on the console. It's located just ahead of the shift lever. ASC is the Automatic Stability Control system.
It's a traction control light. it warns whenever the system is turned on and the car senses a loss of traction. you can deactivate the system by pushing the ASD(dsc) button and holding. this light will illuminate to say: you may lose traction.
Can sometimes be activated by faulty brake(ABS) sensors,ABS pump,While checking ensure that your brake pads aren't worn right down.
If the light still stays up get your local service dealer to scan cars computer for fault code relating to which sensor is perhaps faulty.
I hope this helps you or get back with your findings
Apr 02, 2011 | BMW 318 Cars & Trucks
See page 25 of:
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
TDK CD-RW Burner Sense Key Error
You may try this dvd creator for mac, I always use it to burn music and dvd, it works pretty well for me
http://macdvdcreator.mac-dvd.com
Mar 28, 2008 | Computers & Internet
Fujitsu ScanPartner fi-5120C Pass-Through Scanner Logo
426 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
